How to loop over Excel files in a folder and append them to one Example Set containing all files
ella_
I was trying to loop over 3 Excel files in a folder and append them to one Example Set containing all 3 Example Sets.
Plotting over a continuously id shows that unfortunately my final Example Set contains 3 times the first Example Set.
I was looping over the parameter index of the select operator which selects a file of the loop files subprocess which contains the read Excel operator.
Can someone please help me to solve the problem?
Best
Ella
Attached Process:
<?xml version="1.0" encoding="UTF-8"?><process version="9.5.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.5.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="concurrency:loop_parameters" compatibility="9.5.001" expanded="true" height="82" name="Loop Parameters" width="90" x="45" y="85">
<list key="parameters">
<parameter key="Select.index" value="[1.0;3;2;linear]"/>
</list>
<parameter key="error_handling" value="fail on error"/>
<parameter key="log_performance" value="true"/>
<parameter key="log_all_criteria" value="false"/>
<parameter key="synchronize" value="false"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="concurrency:loop_files" compatibility="9.5.001" expanded="true" height="82" name="Loop Files" width="90" x="45" y="85">
<parameter key="filter_type" value="glob"/>
<parameter key="recursive" value="false"/>
<parameter key="enable_macros" value="false"/>
<parameter key="macro_for_file_name" value="file_name"/>
<parameter key="macro_for_file_type" value="file_type"/>
<parameter key="macro_for_folder_name" value="folder_name"/>
<parameter key="reuse_results" value="false"/>
<operator activated="true" class="read_excel" compatibility="9.5.001" expanded="true" height="68" name="Read Excel" width="90" x="45" y="85">
<parameter key="sheet_selection" value="sheet number"/>
<parameter key="sheet_number" value="1"/>
<parameter key="imported_cell_range" value="A1"/>
<parameter key="first_row_as_names" value="true"/>
<list key="annotations"/>
<parameter key="date_format" value=""/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="read_all_values_as_polynominal" value="false"/>
<list key="data_set_meta_data_information"/>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
<connect from_op="Read Excel" from_port="output" to_port="output 1"/>
<portSpacing port="source_file object" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<operator activated="true" class="select" compatibility="9.5.001" expanded="true" height="68" name="Select" width="90" x="246" y="85">
<parameter key="index" value="1"/>
<parameter key="unfold" value="false"/>
<connect from_op="Loop Files" from_port="output 1" to_op="Select" to_port="collection"/>
<connect from_op="Select" from_port="selected" to_port="output 1"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<operator activated="true" class="append" compatibility="9.5.001" expanded="true" height="82" name="Append" width="90" x="179" y="85">
<parameter key="merge_type" value="all"/>
<operator activated="true" class="generate_id" compatibility="9.5.001" expanded="true" height="82" name="Generate ID" width="90" x="313" y="85">
<parameter key="create_nominal_ids" value="false"/>
<parameter key="offset" value="0"/>
<connect from_op="Loop Parameters" from_port="output 1" to_op="Append" to_port="example set 1"/>
<connect from_op="Append" from_port="merged set" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_port="result 1"/>
</process>
</process>
Excel
Loops + Branches
varunm1
Hello
@ella_
Why don't you directly loop files and append, instead of using the loop parameters?
One issue I found is in the "Select" operator. You hardcoded "1" in that, you change it to macro %{execution_count} and check if you are getting all three.
