<?xml version="1.0" encoding="UTF-8"?><process version="10.1.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.1.002" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="open_file" compatibility="10.1.002" expanded="true" height="68" name="Open File" width="90" x="112" y="34"> <parameter key="resource_type" value="URL"/> <parameter key="filename" value=""/> <parameter key="url" value="https://us.v-cdn.net/6038102/uploads/editor/sf/nq6mm23abhpa.txt"/> </operator> <operator activated="true" class="multiply" compatibility="10.1.002" expanded="true" height="103" name="Multiply" width="90" x="246" y="85"/> <operator activated="true" class="text:read_document" compatibility="10.0.000" expanded="true" height="68" name="Read Document (2)" width="90" x="380" y="34"> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="UTF-8"/> </operator> <operator activated="true" class="text:documents_to_data" compatibility="10.0.000" expanded="true" height="82" name="Documents to Data (2)" width="90" x="514" y="34"> <parameter key="text_attribute" value="text"/> <parameter key="add_meta_information" value="false"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <parameter key="use_processed_text" value="false"/> </operator> <operator activated="true" class="extract_macro" compatibility="10.1.002" expanded="true" height="68" name="Extract Macro" width="90" x="648" y="34"> <parameter key="macro" value="text"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="text"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="hanminer:read_document" compatibility="1.0.003" expanded="true" height="68" name="Read Document" width="90" x="782" y="136"> <parameter key="encoding" value="UTF-8"/> <parameter key="import_from_file" value="false"/> <parameter key="text" value="%{text}"/> <parameter key="file" value="C:/Users/Rui/Downloads/archive (6)-chinese/chinese-dataset-subset.txt"/> </operator> <operator activated="true" class="hanminer:tokenize" compatibility="1.0.003" expanded="true" height="68" name="Tokenize" width="90" x="916" y="136"> <parameter key="high_speed_mode" value="false"/> </operator> <connect from_op="Open File" from_port="file" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Read Document (2)" to_port="file"/> <connect from_op="Multiply" from_port="output 2" to_op="Read Document" to_port="file"/> <connect from_op="Read Document (2)" from_port="output" to_op="Documents to Data (2)" to_port="documents 1"/> <connect from_op="Documents to Data (2)" from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Read Document" from_port="output" to_op="Tokenize" to_port="document set"/> <connect from_op="Tokenize" from_port="document set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<pre class="CodeBlock"><code>
