Altair RISE
Nominate Yourself Now!
How to calculate the difference between every two years and k-means clustering question.
User: "Evelyn"
New Altair Community Member
Updated by Jocelyn
Currently this is my data view
In the result, first, i need to get the difference between revenue-expenses between every two years (2018-2017; 2017-2016..)
The result I get must be in percentage
May I know how to do this? I have tried using generate attribute, date diff also didnt work
Besides that, this is my k-means clustering results
Although the result is correct already, but my lecturer ask me to convert the result into percentage form?
Does anyone can help? Thanks in advance and I'm really appreciate your help.
1 - 2 of 21
    User: "Telcontar120"
    The answer to your first question is to use the Generate Attributes operator. Probably the issue you were facing is that your attribute names appear to be numbers, in which case you might have not referenced them correctly and thus RapidMiner didn't know that you were trying to calculate based on another attribute.  You do that by enclosing the attribute name in brackets.  Also, there are several different ways to generate percentages depending on the denominator you select. But one example would be to define a new attribute such as "2018_percent_change" as ([2018.0]-[2017.0])/[2017.0]
    You would of course need to do this for each attribute you want to create.  If you have a lot of these and the manual construction of these attributes is tedious, this could be automated with a loop and macros as well.
