I'm using auto model in rapidminer 9.5 for a crash dataset. the task is prediction and the "class" column is the target. I chose decision tree, naive bayes, gradient boosted trees, random forest, svm and deep learning. After running, the process only shows results for naive bayes and decision trees and the others face the error below:
Cannot execute log reg calibration learning: Error while training the
H2O model: Illegal argument(s) for GLM model: ERRR on field: _response:
Response cannot be constant.
As I'm new to this software and I should use it for my Msc thesis, I really need help with this problem. I have also attached my data in case you needed to see.
Thank you.
