Separating Column Values on Percentage Basis
![P2017000971](https://us.v-cdn.net/6038102/uploads/defaultavatar/nLP0QHCLH24WL.jpg)
P2017000971
New Altair Community Member
Hello to every one,
thanks For Taking the Time to look into my Question
I will Explain the issue using some examples for better clarification
NO Product Price
1 593
2 623
3 1880
4 2811
5 1208
6 3403
7 2300
8 2406
9 2729
10 2500
Let us Assume we have the Previous Two Columns (i.e. NO and Product Price)
I want to separate their values based on 50% basis of overall values in column
in this Example we have 10 values so the aim is to make it like this :
First Output
NO Product Price
1 593
2 623
3 1880
4 2811
5 1208
Second Output
NO Product Price
6 3403
7 2300
8 2406
9 2729
10 2500
If there is way to generate two different outputs, it is good
Also if there was a way to select a portion depending on my preference that is even better.
Hi @P2017000971,
Here a process (in attached file) that performs what you want to do (based on your example)
Lionel3 -
You can do this pretty easily with Filter Example Range as well, if you know in advance how many records there are and how many you want in each partition.1
