lionelderkrikor,
Your python script worked with the example you provided. I considered this as a solution. However with the dataset I am using "sehid" is the (group), "aankomstdt" admissiondatetime and "ontslagdt" dischargedatetime.
With the python script I adapted the variables but the final count is zero for all examples. What am I doing wrong here?
Hopefully you could help me?
Cheers
Sven
Lionel,
I gave the process a try on the full example range, its running now for 1 day and 20 hours with only 1.2 GB consumption stable over the entire period. What do you think, just let it run untill the finish (in that case, how long would it require by your estimation?) OR there a way to run the process in steps?
Hi Lionel and Balazs
Thanks for the reply, I also thought that overlap is only computable in one batch because patiënt admission is a continuous. Each split of the dataset can bias missing cases that overlap between the subsets. Interesting to "feel" the impact of dimensionality on calculation time. I try to reconstruct how a human brain tries to look for overlap, I wonder if looping with ascending or descending times could not reduce possible combinations. Although theoretically all combinations are possible in overlap, this is only the case if admission and discharge differences are between zero and indefinite which is not realistic. Maybe the number of combinations can be reduced starting from median, average length of stay which could already cover x % of the cases calculated in a fraction of the time?
Thanks anyway!!!!
What is your opinion on interlaps (https://brentp.github.io/interlap/)?
Regards
