🎉Community Raffle - Win $25
Join and Win
Process of X-means cluster with text data
User: "Joanneyu"
New Altair Community Member
Updated by Jocelyn
Hi all,
I want to do x-means cluster with text data, but I am super new with Rapidminer. I followed several different tutorials and ended up with this process.
My data looks like the excel format at left hand side, where I have only one column with several single words.
If would be so nice if someone can confirm whether the process is right or wrong. I want to use X-means cluster because I want to see what is the ideal number of clusters. I am using TF-IDF, and Inside "process document from data", there are tokenize, transform cases, stopwords, and stem (poter). As for "X-Means", I set the k min of 10 and k max 60, with Cosine similarity.
However, the results appear weird to me because cluster 0 has almost all the data. Also, I expected that the results will tell me what would be the most ideal number of clusters? Or did I make any mistake in the process?
Thank you in advance!!!
1 - 1 of 11
    User: "sgenzer"
    hi @Joanneyu there's nothing that I can see wrong with your process (although I must say using Auto Model is MUCH easier than what you're trying to do here with operators). Having one cluster with almost all the items is not unusual per se; could be a very homogenous group, or you're not creating enough/the right features to find differences in your texts.
    Again I'd try Auto Model. :wink:
    Scott
