🎉Community Raffle - Win $25
Join and Win
General guidelines to the use of Parameter Optimization for SVM.
User: "pblack476"
New Altair Community Member
Updated by Jocelyn
Certain learners have infinite possibilities of configuration and the task seems daunting.
So what are some guidelines on how to proceed with this step of model creation? Right now I am trying to optmize a SVM and while AutoModel gave me a starting point on that, it seems there is much more to test. How should I tackle this? What are usually effective parameters to tune in a SVM and are there recommended ranges for them?
Bear in mind that for my application I could leave a model running overnight without problems. But I am trying to understand the best I can the problem and try to avoid brute forcing it if possible.
I am on a 8750h CPU w/ 16 gb RAM
1 - 1 of 11
    User: "varunm1"
    Accepted Answer
    Hello @pblack476
    The three parameters I try to tune in SVM are kernel, C and gamma. Specific Range for C values is hard to inform. But very large C values might over fit the model and also takes more time for processing. You can try C 0 to 20 and check where you are getting best model if its at 20 try to increase C and see if you are getting best model above 20 as well.
    Incase of gamma, lower gamma will have high variance and high gamma will have low variance. You can search for gamma values as well similar to above.
    Their maximum allowed ranges are given in SVM help text in RM
