Hello everybody.
I´m having some problems with a process im trying to build.
So I want to check an existing table (that get´s updated through a scheduler) in my repository for updates, and if there is one, I want another process to start. If there is no update to it, then nothing happens.
To do so, I want to use the Branch-Operator, and the condition of it compares the latest entry of the table to the current date. Unfortunately the results are simply not right.
I saved the most recent date in the table as a macro, the current date also as a macro.
My question now is, how this problem should be entered into the "expression" window in the Branch operator?
I´d be very grateful for your help!
Best,
Richard
<?xml version="1.0" encoding="UTF-8"?><process version="9.5.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.5.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.5.000" expanded="true" height="68" name="Retrieve xy data (2)" width="90" x="45" y="34">
<parameter key="repository_entry" value="../data/xy data"/>
<operator activated="true" class="nominal_to_date" compatibility="9.5.000" expanded="true" height="82" name="Nominal to Date" width="90" x="179" y="34">
<parameter key="attribute_name" value="Erstellt"/>
<parameter key="date_type" value="date_time"/>
<parameter key="date_format" value="dd.MM.yyyy HH:mm"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="keep_old_attribute" value="false"/>
<operator activated="true" class="sort" compatibility="9.5.000" expanded="true" height="82" name="Sort" width="90" x="313" y="34">
<parameter key="sorting_direction" value="decreasing"/>
<operator activated="false" class="date_to_nominal" compatibility="9.5.000" expanded="true" height="82" name="Date to Nominal" width="90" x="447" y="136">
<parameter key="date_format" value="dd.MM.yyyy HH:MM"/>
<operator activated="true" class="extract_macro" compatibility="9.5.000" expanded="true" height="68" name="Extract Macro" width="90" x="648" y="34">
<parameter key="macro" value="Date"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="statistics" value="average"/>
<parameter key="example_index" value="1"/>
<list key="additional_macros"/>
<operator activated="true" breakpoints="after" class="generate_macro" compatibility="9.5.000" expanded="true" height="82" name="Generate Macro" width="90" x="782" y="34">
<parameter key="Current Date" value="date_now()"/>
</list>
<operator activated="true" class="branch" compatibility="9.5.000" expanded="true" height="82" name="Branch" width="90" x="916" y="34">
<parameter key="condition_type" value="expression"/>
<parameter key="expression" value="%{Date}>%{Current Date}"/>
<parameter key="io_object" value="ANOVAMatrix"/>
<parameter key="return_inner_output" value="true"/>
<operator activated="true" class="productivity:execute_process" compatibility="9.5.000" expanded="true" height="82" name="Execute xy" width="90" x="179" y="34">
<parameter key="process_location" value="../../../xy"/>
<parameter key="use_input" value="true"/>
<parameter key="store_output" value="false"/>
<parameter key="propagate_metadata_recursively" value="true"/>
<parameter key="cache_process" value="true"/>
<list key="macros"/>
<parameter key="fail_for_unknown_macros" value="true"/>
<connect from_port="condition" to_op="Execute xy" to_port="input 1"/>
<connect from_op="Execute xy" from_port="result 1" to_port="input 1"/>
<portSpacing port="source_condition" spacing="0"/>
<portSpacing port="sink_input 1" spacing="0"/>
<portSpacing port="sink_input 2" spacing="0"/>
</process>
<operator activated="true" class="throw_exception" compatibility="9.5.000" expanded="true" height="82" name="Throw Exception" width="90" x="179" y="34">
<parameter key="message" value="oh no!"/>
<connect from_port="condition" to_op="Throw Exception" to_port="through 1"/>
<connect from_op="Throw Exception" from_port="through 1" to_port="input 1"/>
</process>
<connect from_op="Retrieve xy data (2)" from_port="output" to_op="Nominal to Date" to_port="example set input"/>
<connect from_op="Nominal to Date" from_port="example set output" to_op="Sort" to_port="example set input"/>
<connect from_op="Sort" from_port="example set output" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Extract Macro" from_port="example set" to_op="Generate Macro" to_port="through 1"/>
<connect from_op="Generate Macro" from_port="through 1" to_op="Branch" to_port="condition"/>
<connect from_op="Branch" from_port="input 1" to_port="result 1"/>
</process>
</process>
