<?xml version="1.0" encoding="UTF-8"?><process version="9.5.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.5.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" breakpoints="after" class="text:read_document" compatibility="8.2.000" expanded="true" height="68" name="Read Document" width="90" x="179" y="136"> <parameter key="file" value="C:\Users\Lionel\Desktop\json.json"/> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <operator activated="true" class="text:json_to_data" compatibility="8.2.000" expanded="true" height="82" name="JSON To Data" width="90" x="380" y="136"> <parameter key="ignore_arrays" value="false"/> <parameter key="limit_attributes" value="false"/> <parameter key="skip_invalid_documents" value="false"/> <parameter key="guess_data_types" value="true"/> <parameter key="keep_missing_attributes" value="false"/> <parameter key="missing_values_aliases" value=", null, NaN, missing"/> </operator> <connect from_op="Read Document" from_port="output" to_op="JSON To Data" to_port="documents 1"/> <connect from_op="JSON To Data" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
