What is the relation between cluster size and centroid table? Which model makes more sense? Why?
NatalySimth
Hello folks,
I am working on comparing two results and I have them as below:
My question is : What is the relation between cluster size and centroid table? Which model makes more sense? Why?
(Case1):
(Case 2):
k-Means Clustering
lionelderkrikor
Hi
@NatalySimth
1. By "compacity" I mean "how close the data points are from their centroid".
2.Create performance and Elbow :
You can easily create a such curve by using an optimization loop via the
Optimize parameters
and
Cluster Distance Performance
operators.
By executing a such process, you will obtain a table of the
Average within Centroid Distance
according to
k
(the number of clusters) :
Then you can plot this table with a
Series
type plot with :
- Index Dimension = k
- Plot Series = Average within centroid distance.
You obtain the following curve :
For this example, we can find that the inflexion point (Elbow) is for k = 4 or k = 5. Thus the optimal number clusters k for this use case is k = 4 or k =5 .
The process used for this post is in attached file.
Hope this helps,
Lionel
PS : To understand the concept of clustering you can visit the RapidMiner Academy : There are interesting videos on this topic :
https://academy.rapidminer.com/catalog?query=cluster
Clustering_Elbow.rmp
lionelderkrikor
Hi
@NatalySimth
Without any additionnal informations, to have a general idea, you can calculate the
which measure the "compacity" of the clusters.(to compare the 2 models).
For that, you have to put a
Performance (Cluster Distance Performance)
operator at the end of your process.
Edit :
I wanted to correct /complete the explanation above :
Assuming that you are using K-means algorithm, a method to find the best k (number of cluster(s)), and thus the best model, is to plot the "Average within centroid distance" according to "k". You will obtain a curve like that (or in the opposite direction since the Average within centroid distance are negative in RapidMiner):
The best k and thus the more relevant model matches with the inflexion point of the curve.
Hope this helps,
Lionel
NatalySimth
Hey
lionelderkrikor
thanls for your explanation. if you allow me what do you mean with the "compacity" of the clusters?
how can I create performance and Elbow? still new to all of these methods.
lionelderkrikor
Hi
@NatalySimth
Optimize parameters
and
operators.
according to
k
Series
type plot with :
Hope this helps,
Lionel
NatalySimth
@lionelderkrikor
Thanks a million!
So useful information.
lionelderkrikor
@NatalySimth
You're welcome !
Lionel
Muhammed_Fatih_
Hi
@lionelderkrikor
thank you for your inspiring answer from above! In this sense, it should be also possible to generate the Ellbow by using the Davies-Bouldin index in order to compare the main criterion, right?
Thank you in advance for your answer!
Regards!
tonyboy9
Better still, just return the Davies-Bouldin index to AutoModel results for k-means. Does anyone understand why this result was removed? I mean interpreting k-means results was already a challenge.
prashant768
lionelderkrikor
thanks for the explanation.
But can you please let me know how you get the inertia plot in rapidminer, as the options present in it are only avg within centroid and DB.
I want to plot it on the basis of inertia criterion. Please help
