Cannot genereate ROC from HBOS example set
I have a model using HBOS to calculate an outlier score. I want to feed that into an "GenerateROC" component to evauluate the scores, like with other outlier detection components.
However, the GenerateROC component gives an design time error that the exampleset coming from the HBOS in facts is not an example set. I use the output connector at the top, without the colors.
I also tried saving the example set first and the feed it in the GenerateROC component in a new process.
In that case, the GenerateROC does give a run time error saying "' '' not found in the labels".
There seems to be something wrong with the metadata of the HBOS output example set. Any help with be great.
Kind regards,
Maarten
