<?xml version="1.0" encoding="UTF-8"?><process version="9.4.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.4.001" expanded="true" height="68" name="Retrieve Polynomial" width="90" x="112" y="85"> <parameter key="repository_entry" value="//Samples/data/Polynomial"/> </operator> <operator activated="true" breakpoints="before,after" class="generate_attributes" compatibility="9.4.001" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="85"> <list key="function_descriptions"> <parameter key="a1" value="a1*1000"/> <parameter key="a2" value="a2*1000"/> <parameter key="a3" value="a3*1000"/> <parameter key="a4" value="a4*1000"/> <parameter key="a5" value="a5*1000"/> </list> <parameter key="keep_all" value="false"/> </operator> <connect from_op="Retrieve Polynomial" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
