Altair RISE
Nominate Yourself Now!
Edit Auto Model process to insert 'vote' operator
User222697
i have used 'Titanic' data example with Auto Model to predict the survived passengers using Naive Bayes and generate a process which i attach here.
My question is, taking as reference the documentation:
https://docs.rapidminer.com/latest/studio/operators/modeling/predictive/ensembles/vote.html
What should I modify exactly in the process I attached to make it work correctly? Can someone give any illustrative example? I would be very grateful.
Thanks very much
Auto Model
varunm1
It should work, maybe the run time data that we are logging is changing due to our manual modifications, you can disable that operator if you are ok with not having run times recorded.
varunm1
Hello
@User222697
To use "vote" operator you need at least two base learners, you cannot use with a one learning algorithm. In the below screenshot, I used your process and made modifications during model training. You can see the left part is where I used to multiply and vote during training and then the right part is where I show the two base learners I used inside vote operator.
Is this what you are looking for? If not, provide us more details so that we can help you with the solution.
User222697
i have tried to do this but shows an unexpected error, see attached screenshot, it is required to implement another changes into the process to work properly?
Thanks
varunm1
Can you try running the XML from below attached file and inform if it is throwing an error?, It is working fine for me.
titanicautomodelprocess.txt
User222697
your model works fine, however, if i try to apply in another processes created by Auto Model, it dont work .. is very strange
varunm1
