<?xml version="1.0" encoding="UTF-8"?><process version="9.4.000-BETA"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.4.000-BETA" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.4.000-BETA" expanded="true" height="68" name="Create ExampleSet" width="90" x="179" y="85"> <parameter key="generator_type" value="attribute functions"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"> <parameter key="test" value="10*rand()"/> <parameter key="label" value="if(test<5,0,1)"/> </list> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="set_role" compatibility="9.4.000-BETA" expanded="true" height="82" name="Set Role" width="90" x="313" y="85"> <parameter key="attribute_name" value="label"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" breakpoints="after" class="numerical_to_binominal" compatibility="9.4.000-BETA" expanded="true" height="82" name="Numerical to Binominal" width="90" x="447" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> <parameter key="min" value="0.0"/> <parameter key="max" value="0.0"/> </operator> <operator activated="true" class="operator_toolbox:smote" compatibility="2.1.000" expanded="true" height="82" name="SMOTE Upsampling" width="90" x="581" y="85"> <parameter key="number_of_neighbours" value="5"/> <parameter key="normalize" value="true"/> <parameter key="equalize_classes" value="false"/> <parameter key="upsampling_size" value="1000"/> <parameter key="auto_detect_minority_class" value="true"/> <parameter key="round_integers" value="true"/> <parameter key="nominal_change_rate" value="0.5"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/> <connect from_op="Numerical to Binominal" from_port="example set output" to_op="SMOTE Upsampling" to_port="exa"/> <connect from_op="SMOTE Upsampling" from_port="ups" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
