How to save a file downloaded from an sFTP server to a repository on RapidMiner server?
Vulentije
Vulentije New Altair Community Member
In a nutshell, I have a flow in which I am downloading a file (say CSV) from an sFTP server and then reading and transforming the data. I know how to set and run this flow locally, but I need to i) have it run on RM server and ii) save the downloaded file on the server's repository, not to my local repository. What is the easiest way to do this ? Thanks in advance for any help or piece of advice! :)
Best Answer
  • tftemme
    tftemme New Altair Community Member
    Answer ✓
    Hi @Vulentije
    Unfortunately we cannot directly parse the file from the SFTP Server to the RM Server (this is what you want to do, right?). The SFTP Download operator downloads a file from a SFTP Server to a directory on your disk (so not specific to your repository).
    You could use first the SFTP Download operator to download the file to a temporary location, then use the corresponding Read operator to read in the data of the file and Store this data set on your remote repository.
    Hopes this helps.
    Fabian
  • kayman
    kayman New Altair Community Member
    In the toolbox extension (download on the market) you will find an sftp operator doing exactly what you need.
  • Vulentije
    Hi Kayman, thank you for your answer. I installed the extension, added the operator but I have a problem configuring it. The operator requires a location on my "local" repository but I want to run this flow on Server and download the file to the server depository. I already know how to set the local one, but I have absolutely no idea how (in which format) to specify a location in operator's settings that will point to a folder on the server. Can you please help me?
  • tftemme
    Answer ✓
    Hi @Vulentije
    Hopes this helps.
    Fabian
