<?xml version="1.0" encoding="UTF-8"?><process version="9.4.000-BETA"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.4.000-BETA" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.4.000-BETA" expanded="true" height="68" name="Create ExampleSet" width="90" x="179" y="85"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="Country, Gender,Q1 Australia,M,Increase Australia,F,Increase, Australia,M,Increase Australia,M,Decrease India,M,Decrease India,F,Increase India,M,Decrease South Africa,F,Decrease UK,F,Increase "/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="multiply" compatibility="9.4.000-BETA" expanded="true" height="103" name="Multiply" width="90" x="246" y="187"/> <operator activated="true" class="generate_attributes" compatibility="9.4.000-BETA" expanded="true" height="82" name="Generate Attributes" width="90" x="380" y="238"> <list key="function_descriptions"> <parameter key="default_count" value="1"/> </list> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="python_scripting:execute_python" compatibility="9.3.000" expanded="true" height="103" name="Execute Python" width="90" x="514" y="85"> <parameter key="script" value="import pandas as pd # rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none) def rm_main(data): df1 = pd.DataFrame(data.groupby(['Country','Gender','Q1'])['Q1']\ .count()).rename(columns={'Q1':'CountQ1'}).reset_index() df2 =pd.pivot_table(data,index = ['Country','Gender'], columns = 'Q1', values = 'Q1', aggfunc = lambda x: len(x), margins_name = 'Q1').fillna(0).reset_index().copy() df2 = df2.assign(CountQ1 = df2.Increase - df2.Decrease, Q1='Net', Net = df2.apply(lambda x: f'({int(x.Increase)}-{int(x.Decrease)})',axis=1))\ .drop(['Increase','Decrease'],axis=1) df3 = pd.concat([df1,df2]).sort_values(['Country','Gender'],ascending=(1,0))[['Country','Gender','Q1','CountQ1','Net']] # connect 2 output ports to see the results return df3"/> <parameter key="notebook_cell_tag_filter" value=""/> <parameter key="use_default_python" value="true"/> <parameter key="package_manager" value="conda (anaconda)"/> </operator> <operator activated="true" class="blending:pivot" compatibility="9.4.000-BETA" expanded="true" height="82" name="Pivot" width="90" x="514" y="238"> <parameter key="group_by_attributes" value="Country|Gender"/> <parameter key="column_grouping_attribute" value="Q1"/> <list key="aggregation_attributes"> <parameter key="default_count" value="count"/> </list> <parameter key="use_default_aggregation" value="false"/> <parameter key="default_aggregation_function" value="first"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="9.4.000-BETA" expanded="true" height="103" name="Replace Missing Values" width="90" x="648" y="238"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.4.000-BETA" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="782" y="238"> <list key="function_descriptions"> <parameter key="Net" value="[count(default_count)_Increase]-[count(default_count)_Decrease]"/> </list> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="rename" compatibility="9.4.000-BETA" expanded="true" height="82" name="Rename" width="90" x="916" y="238"> <parameter key="old_name" value="count(default_count)_Decrease"/> <parameter key="new_name" value="Decrease"/> <list key="rename_additional_attributes"> <parameter key="count(default_count)_Increase" value="Increase"/> </list> </operator> <operator activated="true" class="order_attributes" compatibility="9.4.000-BETA" expanded="true" height="82" name="Reorder Attributes" width="90" x="1050" y="238"> <parameter key="sort_mode" value="user specified"/> <parameter key="attribute_ordering" value="Country|Gender|count(default_count)_Infinity|count(default_count)_-Infinity|Net"/> <parameter key="use_regular_expressions" value="false"/> <parameter key="handle_unmatched" value="append"/> <parameter key="sort_direction" value="descending"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Execute Python" to_port="input 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Pivot" to_port="input"/> <connect from_op="Execute Python" from_port="output 1" to_port="result 1"/> <connect from_op="Pivot" from_port="output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Reorder Attributes" to_port="example set input"/> <connect from_op="Reorder Attributes" from_port="example set output" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
