Nominal to date - cannot pearse as date columns in wrong format
Hi everyone,
I would need some help with my nominal to date conversion: I try to merge to columns, one with the month and one with the year, into one date column.
It should then look something like this:
01/01/2007
01/02/2007
01/03/2007
etc.
So I use the Generate attributes operator to receive only one attribute (out of one column containing the month, so the numbers 1-12, and one column containing the year, so numbers 2007-2019) and then try to format it as a date.
I get the following error message:
"Cannot pearse the date in line 1 for attribute Datum_Total with the date format dd.MM.yyyy. Unpearsable date:
'1.0/2007.0'"
So it seems the month and the year are somehow formatted the wrong way. Can you help me with this?
Best,
Titzaaa
