How to delete a file from a S3 Bucket folder
PBM
We use Amazon S3 to load data into Amazon Redshift Database. After data is loaded we want to clean up the S3 text files. I see the Read, Loop, and Write S3 operators. Does RM allow Deleting files from S3, considering that I have access to delete in S3? Otherwise any workaround suggestions?
Thank You
AWS Azure
sgenzer
hi
@PBM
yep that is pretty much the only way to do it. You can also install the AWS CLI and use the Execute Program operator to run shell script commands.
It would be a logical feature request...
Scott
PBM
Hi all,
Ok it seems that this is a case where RapidMiner does not have the object but then you can extend it by using external scripts. In this case I have used the Execute Python script and boto library.
from boto.s3.connection import S3Connection
S3_BUCKET_NAME='myBucket'
AWS_ACCESS_KEY='myAccesskey'
AWS_SECRET_KEY='mySecretKey'
path_to_file='mysubFolderPath'
def rm_main():
# Create connection
conn = S3Connection(AWS_ACCESS_KEY, AWS_SECRET_KEY)
# Connet to my bucket
bucket = conn.get_bucket(S3_BUCKET_NAME)
# Get subdirectory info and delete files (except the subdirectory itself)
for key in bucket.list(prefix=path_to_file, delimiter='/'):
if key.name != path_to_file:
bucket.delete_key(key)
return
if __name__ == "__main__":
rm_main()
Thank You
sgenzer
hi
@PBM
Scott
