<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="9.3.001" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34"> <parameter key="excel_file" value="C:\Users\Lionel\Downloads\Data para clusterizar.xlsx"/> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="idCat_inversion.true.polynominal.attribute"/> <parameter key="1" value="idCarrera.true.polynominal.attribute"/> <parameter key="2" value="idDestinoDeseado.true.polynominal.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="text_to_nominal" compatibility="9.3.001" expanded="true" height="82" name="Text to Nominal" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="text"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="text"/> <parameter key="block_type" value="value_matrix"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="9.3.001" expanded="true" height="103" name="Nominal to Numerical" width="90" x="313" y="34"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value="idCat_inversion"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="coding_type" value="dummy coding"/> <parameter key="use_comparison_groups" value="false"/> <list key="comparison_groups"/> <parameter key="unexpected_value_handling" value="all 0 and warning"/> <parameter key="use_underscore_in_name" value="false"/> </operator> <operator activated="true" breakpoints="after" class="concurrency:k_means" compatibility="9.3.001" expanded="true" height="82" name="Clustering" width="90" x="514" y="34"> <parameter key="add_cluster_attribute" value="true"/> <parameter key="add_as_label" value="false"/> <parameter key="remove_unlabeled" value="false"/> <parameter key="k" value="6"/> <parameter key="max_runs" value="10"/> <parameter key="determine_good_start_values" value="true"/> <parameter key="measure_types" value="MixedMeasures"/> <parameter key="mixed_measure" value="MixedEuclideanDistance"/> <parameter key="nominal_measure" value="NominalDistance"/> <parameter key="numerical_measure" value="EuclideanDistance"/> <parameter key="divergence" value="SquaredEuclideanDistance"/> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="1.0"/> <parameter key="kernel_sigma1" value="1.0"/> <parameter key="kernel_sigma2" value="0.0"/> <parameter key="kernel_sigma3" value="2.0"/> <parameter key="kernel_degree" value="3.0"/> <parameter key="kernel_shift" value="1.0"/> <parameter key="kernel_a" value="1.0"/> <parameter key="kernel_b" value="0.0"/> <parameter key="max_optimization_steps" value="100"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="multiply" compatibility="9.3.001" expanded="true" height="103" name="Multiply" width="90" x="380" y="238"/> <operator activated="true" class="model_simulator:cluster_model_visualizer" compatibility="9.3.001" expanded="true" height="82" name="Cluster Model Visualizer" width="90" x="782" y="34"/> <operator activated="true" class="sort" compatibility="9.3.001" expanded="true" height="82" name="Sort" width="90" x="514" y="238"> <parameter key="attribute_name" value="cluster"/> <parameter key="sorting_direction" value="increasing"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.3.001" expanded="true" height="82" name="Generate Attributes" width="90" x="715" y="238"> <list key="function_descriptions"> <parameter key="cluster_label" value="cluster"/> </list> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="set_role" compatibility="9.3.001" expanded="true" height="82" name="Set Role" width="90" x="849" y="238"> <parameter key="attribute_name" value="cluster_label"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="select_attributes" compatibility="9.3.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="983" y="187"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="cluster_label|id|idCarrera = Administración|idCarrera = Antropología|idCarrera = Arqueología|idCarrera = ArquitecturayUrbanismo|idCarrera = ArtesEscénicas|idCarrera = ArteyDiseño|idCarrera = Biología|idCarrera = CienciasdelaComunicación|idCarrera = CienciasdelaSalud|idCarrera = CienciasSociales|idCarrera = Contabilidad|idCarrera = Derecho|idCarrera = DiseñoGráfico|idCarrera = Economía|idCarrera = Educación|idCarrera = Enfermería|idCarrera = Finanzas|idCarrera = GestiónyAltaDirección|idCarrera = Hoteleríayturismo|idCarrera = Idiomas|idCarrera = IngenieríaAmbiental|idCarrera = IngenieríaCivil|idCarrera = IngenieríadeSistemas|idCarrera = IngenieríaIndustrial|idCarrera = IngenieríaMecanica|idCarrera = IngenieríaQuimica|idCarrera = Marketing|idCarrera = MedicinaHumana|idCarrera = MedicinaVeterinaria|idCarrera = Música|idCarrera = NegociosInternacionales|idCarrera = Otros|idCarrera = Psicología|idCarrera = Publicidadyafines|idCarrera = TrabajoSocial|idCat_inversion = Inversiónalta|idCat_inversion = Inversiónbásica|idCat_inversion = Inversiónpromedio|idDestinoDeseado = Afganistán|idDestinoDeseado = Albania|idDestinoDeseado = Alemania|idDestinoDeseado = Argelia|idDestinoDeseado = Argentina|idDestinoDeseado = Armenia|idDestinoDeseado = Australia|idDestinoDeseado = Austria|idDestinoDeseado = Azerbaiyán|idDestinoDeseado = Bahrein|idDestinoDeseado = Bangladesh|idDestinoDeseado = Benin|idDestinoDeseado = Bielorrusia|idDestinoDeseado = Bolivia|idDestinoDeseado = BosniaHerzegovina|idDestinoDeseado = Botsuana|idDestinoDeseado = Brasil|idDestinoDeseado = Bulgaria|idDestinoDeseado = BurkinaFaso|idDestinoDeseado = Bélgica|idDestinoDeseado = CaboVerde|idDestinoDeseado = Camboya|idDestinoDeseado = Camerún|idDestinoDeseado = Canadá|idDestinoDeseado = Chile|idDestinoDeseado = ChinaContinental|idDestinoDeseado = Colombia|idDestinoDeseado = Corea|idDestinoDeseado = CostadeMarfil|idDestinoDeseado = CostaRica|idDestinoDeseado = Croacia|idDestinoDeseado = Dinamarca|idDestinoDeseado = EAU|idDestinoDeseado = Ecuador|idDestinoDeseado = Egipto|idDestinoDeseado = ElSalvador|idDestinoDeseado = Eslovaquia|idDestinoDeseado = Eslovenia|idDestinoDeseado = España|idDestinoDeseado = EstadosUnidos|idDestinoDeseado = Estonia|idDestinoDeseado = Etiopía|idDestinoDeseado = Fiji|idDestinoDeseado = Filipinas|idDestinoDeseado = Finlandia|idDestinoDeseado = Francia|idDestinoDeseado = Gabón|idDestinoDeseado = Georgia|idDestinoDeseado = Ghana|idDestinoDeseado = Grecia|idDestinoDeseado = Guatemala|idDestinoDeseado = HongKong|idDestinoDeseado = Hungría|idDestinoDeseado = India|idDestinoDeseado = Indonesia|idDestinoDeseado = Irlanda|idDestinoDeseado = Irán|idDestinoDeseado = Islandia|idDestinoDeseado = Italia|idDestinoDeseado = Japón|idDestinoDeseado = Jordán|idDestinoDeseado = Kazajstán|idDestinoDeseado = Kenia|idDestinoDeseado = Kirguizstán|idDestinoDeseado = Kuwait|idDestinoDeseado = Laos|idDestinoDeseado = Letonia|idDestinoDeseado = Liberia|idDestinoDeseado = Lituania|idDestinoDeseado = Líbano|idDestinoDeseado = Macedonia|idDestinoDeseado = Malasia|idDestinoDeseado = Malawi|idDestinoDeseado = Malta|idDestinoDeseado = Marruecos|idDestinoDeseado = Mauricio|idDestinoDeseado = Moldavia|idDestinoDeseado = Mongolia|idDestinoDeseado = Montenegro|idDestinoDeseado = Mozambique|idDestinoDeseado = Myanmar|idDestinoDeseado = México|idDestinoDeseado = Namibia|idDestinoDeseado = Nepal|idDestinoDeseado = Nicaragua|idDestinoDeseado = Nigeria|idDestinoDeseado = Noruega|idDestinoDeseado = NuevaZelanda|idDestinoDeseado = Omán|idDestinoDeseado = Pakistán|idDestinoDeseado = Panamá|idDestinoDeseado = Paraguay|idDestinoDeseado = PaísesBajos|idDestinoDeseado = Perú|idDestinoDeseado = Polonia|idDestinoDeseado = Portugal|idDestinoDeseado = PuertoRico|idDestinoDeseado = ReinoUnido|idDestinoDeseado = RepublicaCheca|idDestinoDeseado = RepúblicaDominicana|idDestinoDeseado = Ruanda|idDestinoDeseado = Rumania|idDestinoDeseado = Rusia|idDestinoDeseado = Senegal|idDestinoDeseado = Serbia|idDestinoDeseado = Seychelles|idDestinoDeseado = Singapur|idDestinoDeseado = SriLanka|idDestinoDeseado = Sudáfrica|idDestinoDeseado = Suecia|idDestinoDeseado = Suiza|idDestinoDeseado = Tailandia|idDestinoDeseado = Taiwán|idDestinoDeseado = Tanzania|idDestinoDeseado = Tayikistan|idDestinoDeseado = Togo|idDestinoDeseado = Turquía|idDestinoDeseado = Túnez|idDestinoDeseado = Ucrania|idDestinoDeseado = Uganda|idDestinoDeseado = Uruguay|idDestinoDeseado = Venezuela|idDestinoDeseado = Vietnam"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="false" class="select_attributes" compatibility="9.3.001" expanded="true" height="82" name="Select Attributes" width="90" x="983" y="391"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="cluster_label|id|idCarrera|idCat_inversion|idDestinoDeseado"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.3.001" expanded="true" height="103" name="Decision Tree" width="90" x="1117" y="187"> <parameter key="criterion" value="gain_ratio"/> <parameter key="maximal_depth" value="20"/> <parameter key="apply_pruning" value="true"/> <parameter key="confidence" value="0.25"/> <parameter key="apply_prepruning" value="false"/> <parameter key="minimal_gain" value="0.01"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="number_of_prepruning_alternatives" value="3"/> </operator> <connect from_op="Read Excel" from_port="output" to_op="Text to Nominal" to_port="example set input"/> <connect from_op="Text to Nominal" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Cluster Model Visualizer" to_port="model"/> <connect from_op="Clustering" from_port="clustered set" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Sort" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Cluster Model Visualizer" to_port="clustered data"/> <connect from_op="Cluster Model Visualizer" from_port="visualizer output" to_port="result 4"/> <connect from_op="Cluster Model Visualizer" from_port="model output" to_port="result 3"/> <connect from_op="Sort" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Set Role" from_port="original" to_port="result 2"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> <portSpacing port="sink_result 5" spacing="0"/> </process> </operator> </process>
