Dear community,
this is the first time I try to build a text mining process and I cannot find my mistake: When trying to run the process, I get a error message saying "unnamed error. no message". Can you help?
Here is my code:
<?xml version="1.0" encoding="UTF-8"?><process version="9.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.3.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.3.000" expanded="true" height="68" name="Retrieve" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Masterarbeit/Data/Finanzen.net"/>
<operator activated="true" class="nominal_to_text" compatibility="9.3.000" expanded="true" height="82" name="Nominal to Text" width="90" x="179" y="34">
<parameter key="attribute" value="Titel"/>
<parameter key="value_type" value="nominal"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="except_block_type" value="single_value"/>
<operator activated="true" class="text:process_document_from_data" compatibility="8.2.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="380" y="34">
<parameter key="create_word_vector" value="true"/>
<parameter key="vector_creation" value="Binary Term Occurrences"/>
<parameter key="add_meta_information" value="true"/>
<parameter key="keep_text" value="false"/>
<parameter key="prune_method" value="none"/>
<parameter key="prune_below_percent" value="3.0"/>
<parameter key="prune_above_percent" value="30.0"/>
<parameter key="prune_below_rank" value="0.05"/>
<parameter key="prune_above_rank" value="0.95"/>
<parameter key="datamanagement" value="double_sparse_array"/>
<parameter key="data_management" value="auto"/>
<parameter key="select_attributes_and_weights" value="false"/>
<list key="specify_weights"/>
<operator activated="true" class="text:tokenize" compatibility="8.2.000" expanded="true" height="68" name="Tokenize" width="90" x="179" y="34">
<parameter key="mode" value="non letters"/>
<parameter key="characters" value=".:"/>
<parameter key="language" value="English"/>
<parameter key="max_token_length" value="3"/>
<operator activated="true" class="text:transform_cases" compatibility="8.2.000" expanded="true" height="68" name="Transform Cases" width="90" x="313" y="34">
<parameter key="transform_to" value="lower case"/>
<operator activated="true" class="text:filter_stopwords_german" compatibility="8.2.000" expanded="true" height="68" name="Filter Stopwords (German)" width="90" x="447" y="34">
<parameter key="stop_word_list" value="Standard"/>
<operator activated="true" class="text:filter_by_length" compatibility="8.2.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="648" y="34">
<parameter key="min_chars" value="3"/>
<parameter key="max_chars" value="10000"/>
<operator activated="false" class="text:generate_n_grams_terms" compatibility="8.2.000" expanded="true" height="68" name="Generate n-Grams (Terms)" width="90" x="246" y="238">
<parameter key="max_length" value="2"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (German)" to_port="document"/>
<connect from_op="Filter Stopwords (German)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="retrieve" compatibility="9.3.000" expanded="true" height="68" name="Retrieve GRESD" width="90" x="45" y="238">
<parameter key="repository_entry" value="../Data/GRESD"/>
<operator activated="true" class="retrieve" compatibility="9.3.000" expanded="true" height="68" name="Retrieve Negationsliste" width="90" x="45" y="391">
<parameter key="repository_entry" value="../Data/Negationsliste"/>
<operator activated="true" class="operator_toolbox:dictionary_sentiment_learner" compatibility="2.0.001" expanded="true" height="82" name="Dictionary-Based Sentiment (Documents)" width="90" x="246" y="289">
<parameter key="value_attribute" value="Klassifizierung"/>
<parameter key="key_attribute" value="Wort"/>
<parameter key="negation_attribute" value="Negationen"/>
<parameter key="negation_window_size" value="1"/>
<parameter key="use_symmetric_negation_window" value="false"/>
<operator activated="true" class="text:data_to_documents" compatibility="8.2.000" expanded="true" height="68" name="Data to Documents" width="90" x="514" y="85">
<operator activated="true" class="operator_toolbox:apply_model_documents" compatibility="2.0.001" expanded="true" height="103" name="Apply Model (Documents)" width="90" x="447" y="289">
<connect from_op="Retrieve" from_port="output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="Data to Documents" to_port="example set"/>
<connect from_op="Retrieve GRESD" from_port="output" to_op="Dictionary-Based Sentiment (Documents)" to_port="exa"/>
<connect from_op="Retrieve Negationsliste" from_port="output" to_op="Dictionary-Based Sentiment (Documents)" to_port="neg"/>
<connect from_op="Dictionary-Based Sentiment (Documents)" from_port="mod" to_op="Apply Model (Documents)" to_port="mod"/>
<connect from_op="Data to Documents" from_port="documents" to_op="Apply Model (Documents)" to_port="doc"/>
<connect from_op="Apply Model (Documents)" from_port="exa" to_port="result 1"/>
</process>
</process>
Thanks a lot on advance!
