<?xml version="1.0" encoding="UTF-8"?><process version="9.3.000"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.3.000" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="retrieve" compatibility="9.3.000" expanded="true" height="68" name="Retrieve crime" width="90" x="45" y="85"><br> <parameter key="repository_entry" value="//Local Repository/crime"/><br> </operator><br> <operator activated="true" class="retrieve" compatibility="9.3.000" expanded="true" height="68" name="Retrieve crime map" width="90" x="45" y="187"><br> <parameter key="repository_entry" value="//Local Repository/crime map"/><br> </operator><br> <operator activated="true" class="concurrency:join" compatibility="9.3.000" expanded="true" height="82" name="Join" width="90" x="246" y="85"><br> <parameter key="remove_double_attributes" value="true"/><br> <parameter key="join_type" value="left"/><br> <parameter key="use_id_attribute_as_key" value="false"/><br> <list key="key_attributes"><br> <parameter key="crime" value="crime"/><br> </list><br> <parameter key="keep_both_join_attributes" value="false"/><br> </operator><br> <operator activated="true" class="replace_missing_values" compatibility="9.3.000" expanded="true" height="103" name="Replace Missing Values" width="90" x="380" y="85"><br> <parameter key="return_preprocessing_model" value="false"/><br> <parameter key="create_view" value="false"/><br> <parameter key="attribute_filter_type" value="single"/><br> <parameter key="attribute" value="crime type"/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> <parameter key="default" value="value"/><br> <list key="columns"/><br> <parameter key="replenishment_value" value="property crime"/><br> </operator><br> <connect from_op="Retrieve crime" from_port="output" to_op="Join" to_port="left"/><br> <connect from_op="Retrieve crime map" from_port="output" to_op="Join" to_port="right"/><br> <connect from_op="Join" from_port="join" to_op="Replace Missing Values" to_port="example set input"/><br> <connect from_op="Replace Missing Values" from_port="example set output" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
crime=="murder"||crime=="rape"||crime=="Crime3", "violence crime", "property crime")if(
