<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document" width="90" x="112" y="34"> <parameter key="text" value="this one contains reference"/> <parameter key="add label" value="false"/> <parameter key="label_type" value="nominal"/> </operator> <operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document (2)" width="90" x="112" y="136"> <parameter key="text" value="this one doesn't"/> <parameter key="add label" value="false"/> <parameter key="label_type" value="nominal"/> </operator> <operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document (3)" width="90" x="112" y="238"> <parameter key="text" value="this one doesn't either"/> <parameter key="add label" value="false"/> <parameter key="label_type" value="nominal"/> </operator> <operator activated="true" class="text:documents_to_data" compatibility="8.1.000" expanded="true" height="124" name="Documents to Data" width="90" x="246" y="34"> <parameter key="text_attribute" value="myDoc"/> <parameter key="add_meta_information" value="true"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="filter_examples" compatibility="9.2.001" expanded="true" height="103" name="Filter Examples" width="90" x="380" y="34"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="custom_filters"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"> <parameter key="filters_entry_key" value="myDoc.does_not_contain.reference"/> </list> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="true"/> </operator> <operator activated="true" class="text:data_to_documents" compatibility="8.1.000" expanded="true" height="68" name="Data to Documents" width="90" x="514" y="34"> <parameter key="select_attributes_and_weights" value="false"/> <list key="specify_weights"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Documents to Data" to_port="documents 2"/> <connect from_op="Create Document (3)" from_port="output" to_op="Documents to Data" to_port="documents 3"/> <connect from_op="Documents to Data" from_port="example set" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
