Why am I getting "inadmissible input" for regex in "finds" expression?
I have a Generate Attributes operator with an expression that uses the "finds" function. It takes the existing nominal attribute Link_prefix, which contains URL strings, and I want to check for the existence of an IP address in the URL. My expression looks like this:
finds(Link_prefix, "\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}")
i.e. a regex looking for four numbers from 1-3 digits, separated by periods. However, it gives me the following error message: Error: Inadmissible input at "". It has an arrow pointing at the opening quotes in the regex expression. What am I doing wrong? Why is the opening quotes of the regex producing an error? I've looked at several questions in RapidMiner Community with examples of regex expressions, and they look like they're formatted the same way mine is.
My xml details are as follows. (Please don't ask for the entire process xml. It's lengthy, and sensitive.)
- Version:
- Operator:
Thanks for any help!! I'm getting frustrated with repeated roadblocks in simple attribute extraction, before I even get to the modeling.
- Version:
<?xml version="1.0" encoding="UTF-8"?><process version="9.0.003">
- Operator:
<operator activated="true" class="generate_attributes" compatibility="9.0.003" expanded="true" height="82" name="Generate Attributes (4)" width="90" x="581" y="34">
<parameter key="IP_in_link" value="finds(Link_prefix, "\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}")"/>
</list>
1 - 3 of
31
- finds(URL,"\\d{1,3}\\.\\d{1,3}\\.\\d{1,3}\\.\\d{1,3}")
jacobcybulski
New Altair Community Member
Accepted Answer
Try changing you backslashes into double backslashes. The first will ensure that the second will be used as part of your regular expression, otherwise a single backslash before "d" would simply escape "d" making it a "normal" character (which already is). In other words use the following function with a regular expression:
No way! That actually worked!
If I understand this correctly, the first slash is string control, which escapes to make its follower a part of the string itself. Then once the string is evaluated as a regular expression, the second slash is regular expression control, which escapes to make its follower one of the regular expression control characters... I think. Correct me if I'm wrong. And it feels like a confusing way for RapidMiner to interpret things, which ought to be clearly called out. But thanks for the solution!
1 - 1 of
11
