Correlations
Papad
I have a dataset which contains speed and pressure attributes. There is for sure a correlation between them, I know it by default, but how can I show it using a model?
I want to have the percentage, weight or whatever I can have.
About the model, I am using linear regression because my dataset has linear relationship with time(for examples I have these attributes during a day).
Thanks in advance.
Correlation
David_A
Typically the correlation is measured as a score between -1 and 1. Where 1 indicates perfect correlation, 0 no correlation and -1 meaning the values have an exact opposite behavior (if one goes up. the other goes down).
the easiest way to calculate the correlation between two or more attributes is to use the
Correlation Matrix
Operator.
If you want to check for several attribute, which one correlates the most to a label, you can also use the
Weight by Correlation
. Finally, if you want to extract or calculate the results of the Correlation Matrix, I recommend you the
Matrix to ExampleSet
operator from the
Converters extension
Best,
David
David_A
Correlation Matrix
Operator.
operator from the
Best,
David
