Message: Could not initialize class org.nd4j.linalg.factory.Nd4j
singh
Process failed
Stack trace:
com.rapidminer.extension.deeplearning.tools.DL4JConverter.exampleSet2DataSet(DL4JConverter.java:186)
com.rapidminer.extension.deeplearning.operators.SequentialNetwork.prepareInput(SequentialNetwork.java:131)
com.rapidminer.extension.deeplearning.operators.AbstractSequentialNetworkOperator.doWork(AbstractSequentialNetworkOperator.java:243)
com.rapidminer.extension.deeplearning.operators.SequentialNetwork.doWork(SequentialNetwork.java:70)
com.rapidminer.operator.Operator.execute(Operator.java:1026)
com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:812)
com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:807)
java.security.AccessController.doPrivileged(Native Method)
com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807)
com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423)
com.rapidminer.Process.executeRoot(Process.java:1386)
com.rapidminer.Process.execute(Process.java:1327)
com.rapidminer.Process.run(Process.java:1300)
com.rapidminer.Process.run(Process.java:1186)
com.rapidminer.Process.run(Process.java:1139)
com.rapidminer.Process.run(Process.java:1134)
com.rapidminer.Process.run(Process.java:1124)
com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
Errors
varunm1
Hello
@singh
Can you inform the if you are running the Deep Learning extension on GPU or CPU? If you are running on GPU which version of CUDA are you using? Also if possible can you provide XML code (View --> Show Panel --> XML)?
You should also check these three requirements.
1. Execution on GPU is currently only available on NVIDIA GPUs in combination with CUDA version 9.0.
2. This extension uses the java library DeepLearning4J (version 1.0-beta).
3. No support for 32-bit.
Thanks
singh
i am running the Deep Learning extension on CPU
singh
using 64 bit
singh
how to activate this extension "java library DeepLearning4J (version 1.0-beta)"?
