"min_rows error; Gradient Boosted Tree"
mansour_ebrahim
Dear All
I am trying to run a gradient boosted tree operator on my data with 3 categories as label feature. It keeps trying posting me the following error:
The 'min_rows' parameter must be smaller than or equal to the (size of the input data) *2.
I have tried different numbers from 0 to 100 but it didn't work.
Appreciate your helpful thoughts.
Regards.
Mansour
Errors
varunm1
Hello
@mansour_ebrahim
Can you post your XML code (View--> Show Panel --> XML) here and data if possible? We will can check it.
Thanks
Varun
mansour_ebrahim
Hi Varun
XML codes are:
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.2.000" expanded="true" height="68" name="Retrieve Hot original dataset" width="90" x="45" y="34">
<parameter key="repository_entry" value="//MEQ/lamb_2019-03-08/uncalibrated/unsmoothed/unscaled/raw/median/hot/Hot original dataset"/>
<operator activated="true" class="select_attributes" compatibility="9.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="246" y="34">
<parameter key="attribute" value=""/>
<parameter key="attributes" value="2 categories|ABATTOIR|carcass_weight|dam_breed|DATE|grade_market|imf|integration_time|ph|seasonality|sex|shear_force|sire_breed|UniqueID"/>
<operator activated="true" class="set_role" compatibility="9.2.000" expanded="true" height="82" name="Set Role" width="90" x="447" y="34">
<parameter key="attribute_name" value="3 categories"/>
<operator activated="true" class="concurrency:cross_validation" compatibility="8.2.000" expanded="true" height="166" name="Gradient Boosted Trees (2)" width="90" x="648" y="34">
<parameter key="split_on_batch_attribute" value="false"/>
<parameter key="leave_one_out" value="false"/>
<parameter key="number_of_folds" value="10"/>
<parameter key="sampling_type" value="automatic"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="h2o:gradient_boosted_trees" compatibility="9.2.000" expanded="true" height="103" name="Gradient Boosted Trees" width="90" x="179" y="34">
<parameter key="number_of_trees" value="100"/>
<parameter key="reproducible" value="false"/>
<parameter key="maximum_number_of_threads" value="4"/>
<parameter key="maximal_depth" value="10"/>
<parameter key="min_rows" value="1.0"/>
<parameter key="min_split_improvement" value="0.0"/>
<parameter key="number_of_bins" value="20"/>
<parameter key="learning_rate" value="0.01"/>
<parameter key="sample_rate" value="1.0"/>
<parameter key="distribution" value="AUTO"/>
<parameter key="early_stopping" value="false"/>
<parameter key="stopping_rounds" value="1"/>
<parameter key="stopping_metric" value="AUTO"/>
<parameter key="stopping_tolerance" value="0.001"/>
<parameter key="max_runtime_seconds" value="0"/>
<list key="expert_parameters"/>
<connect from_port="training set" to_op="Gradient Boosted Trees" to_port="training set"/>
<connect from_op="Gradient Boosted Trees" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model (7)" width="90" x="45" y="30">
<parameter key="create_view" value="false"/>
<operator activated="true" class="multiply" compatibility="9.2.000" expanded="true" height="103" name="Multiply" width="90" x="45" y="136"/>
<operator activated="true" class="performance" compatibility="9.2.000" expanded="true" height="82" name="Performance (7)" width="90" x="313" y="34">
<parameter key="use_example_weights" value="true"/>
<operator activated="true" class="performance_classification" compatibility="9.2.000" expanded="true" height="82" name="Performance" width="90" x="246" y="187">
<parameter key="main_criterion" value="first"/>
<parameter key="accuracy" value="true"/>
<parameter key="classification_error" value="true"/>
<parameter key="kappa" value="true"/>
<parameter key="weighted_mean_recall" value="true"/>
<parameter key="weighted_mean_precision" value="true"/>
<parameter key="spearman_rho" value="true"/>
<parameter key="kendall_tau" value="true"/>
<parameter key="absolute_error" value="true"/>
<parameter key="relative_error" value="true"/>
<parameter key="relative_error_lenient" value="true"/>
<parameter key="relative_error_strict" value="false"/>
<parameter key="normalized_absolute_error" value="true"/>
<parameter key="root_mean_squared_error" value="true"/>
<parameter key="root_relative_squared_error" value="true"/>
<parameter key="squared_error" value="true"/>
<parameter key="correlation" value="true"/>
<parameter key="squared_correlation" value="true"/>
<parameter key="cross-entropy" value="true"/>
<parameter key="margin" value="true"/>
<parameter key="soft_margin_loss" value="true"/>
<parameter key="logistic_loss" value="true"/>
<parameter key="skip_undefined_labels" value="true"/>
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model (7)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (7)" to_port="unlabelled data"/>
<connect from_op="Apply Model (7)" from_port="labelled data" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Performance (7)" to_port="labelled data"/>
<connect from_op="Multiply" from_port="output 2" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance (7)" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance" from_port="performance" to_port="performance 2"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
<portSpacing port="sink_performance 3" spacing="0"/>
</process>
<connect from_op="Retrieve Hot original dataset" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Gradient Boosted Trees (2)" to_port="example set"/>
<connect from_op="Gradient Boosted Trees (2)" from_port="model" to_port="result 1"/>
<connect from_op="Gradient Boosted Trees (2)" from_port="performance 1" to_port="result 2"/>
<connect from_op="Gradient Boosted Trees (2)" from_port="performance 2" to_port="result 3"/>
</process>
</process>
varunm1
Hello
@mansour_ebrahim
I tried recreating error with IRIS dataset (with your process) but it worked fine. Can you provide your data here or on personal message? If we can recreate the error then we can understand the issue.
Thank you
