i have dataset and i want to cluster one feature to three clusters, i choose kmeans, kmedoid and xmean algorithms to preform this clustering then i want to evaluate which algorithm will perform better clustering.
i put the three algorithms in loop parameter but i couldn't know where can i put the cluster distance performance operator . i want to see the avg centroid and Davis bouldin measures for each model and according to them then choose the bset model will perform the best clustering .
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve Engineering_majors1" width="90" x="45" y="34">
<parameter key="repository_entry" value="../data/Engineering_majors1"/>
<operator activated="true" class="select_attributes" compatibility="9.2.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="85">
<parameter key="attribute" value="c_cons_sum"/>
<operator activated="true" class="normalize" compatibility="7.5.003" expanded="true" height="103" name="Normalize" width="90" x="313" y="136">
<parameter key="return_preprocessing_model" value="false"/>
<parameter key="create_view" value="true"/>
<parameter key="value_type" value="numeric"/>
<parameter key="except_value_type" value="real"/>
<parameter key="block_type" value="value_series"/>
<parameter key="except_block_type" value="value_series_end"/>
<parameter key="method" value="range transformation"/>
<parameter key="min" value="0.0"/>
<parameter key="max" value="1.0"/>
<parameter key="allow_negative_values" value="false"/>
<operator activated="true" class="loop_parameters" compatibility="6.0.003" expanded="true" height="103" name="Loop Parameters" width="90" x="447" y="136">
<list key="parameters">
<parameter key="Select Subprocess.select_which" value="[1.0;4;4;linear]"/>
</list>
<parameter key="error_handling" value="fail on error"/>
<parameter key="synchronize" value="false"/>
<operator activated="true" class="multiply" compatibility="9.2.001" expanded="true" height="82" name="Multiply" width="90" x="45" y="85"/>
<operator activated="true" class="select_subprocess" compatibility="9.2.001" expanded="true" height="103" name="Select Subprocess" width="90" x="246" y="85">
<parameter key="select_which" value="4"/>
<operator activated="true" class="concurrency:k_means" compatibility="9.2.001" expanded="true" height="82" name="Clustering" width="90" x="45" y="85">
<parameter key="add_cluster_attribute" value="true"/>
<parameter key="add_as_label" value="true"/>
<parameter key="remove_unlabeled" value="false"/>
<parameter key="k" value="5"/>
<parameter key="max_runs" value="10"/>
<parameter key="determine_good_start_values" value="true"/>
<parameter key="measure_types" value="BregmanDivergences"/>
<parameter key="mixed_measure" value="MixedEuclideanDistance"/>
<parameter key="nominal_measure" value="NominalDistance"/>
<parameter key="numerical_measure" value="EuclideanDistance"/>
<parameter key="divergence" value="SquaredEuclideanDistance"/>
<parameter key="kernel_type" value="radial"/>
<parameter key="kernel_gamma" value="1.0"/>
<parameter key="kernel_sigma1" value="1.0"/>
<parameter key="kernel_sigma2" value="0.0"/>
<parameter key="kernel_sigma3" value="2.0"/>
<parameter key="kernel_degree" value="3.0"/>
<parameter key="kernel_shift" value="1.0"/>
<parameter key="kernel_a" value="1.0"/>
<parameter key="kernel_b" value="0.0"/>
<parameter key="max_optimization_steps" value="100"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<connect from_port="input 1" to_op="Clustering" to_port="example set"/>
<connect from_op="Clustering" from_port="cluster model" to_port="output 1"/>
<connect from_op="Clustering" from_port="clustered set" to_port="output 2"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
<portSpacing port="sink_output 3" spacing="0"/>
</process>
<operator activated="true" class="k_medoids" compatibility="7.5.003" expanded="true" height="82" name="K-Medoids" width="90" x="45" y="187">
<parameter key="k" value="3"/>
<parameter key="use_local_random_seed" value="true"/>
<parameter key="measure_types" value="MixedMeasures"/>
<parameter key="divergence" value="GeneralizedIDivergence"/>
<connect from_port="input 1" to_op="K-Medoids" to_port="example set"/>
<connect from_op="K-Medoids" from_port="cluster model" to_port="output 1"/>
<connect from_op="K-Medoids" from_port="clustered set" to_port="output 2"/>
</process>
<operator activated="true" class="x_means" compatibility="9.2.001" expanded="true" height="82" name="X-Means" width="90" x="45" y="34">
<parameter key="k_min" value="3"/>
<parameter key="k_max" value="60"/>
<parameter key="measure_types" value="NumericalMeasures"/>
<parameter key="clustering_algorithm" value="KMeans"/>
<connect from_port="input 1" to_op="X-Means" to_port="example set"/>
<connect from_op="X-Means" from_port="cluster model" to_port="output 1"/>
<connect from_op="X-Means" from_port="clustered set" to_port="output 2"/>
</process>
<operator activated="true" class="cluster_distance_performance" compatibility="9.2.001" expanded="true" height="103" name="Performance" width="90" x="380" y="85">
<parameter key="main_criterion" value="Avg. within centroid distance"/>
<parameter key="main_criterion_only" value="false"/>
<parameter key="normalize" value="false"/>
<parameter key="maximize" value="false"/>
<connect from_port="input 1" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Select Subprocess" to_port="input 1"/>
<connect from_op="Select Subprocess" from_port="output 1" to_op="Performance" to_port="cluster model"/>
<connect from_op="Select Subprocess" from_port="output 2" to_op="Performance" to_port="example set"/>
<connect from_op="Performance" from_port="performance" to_port="performance"/>
<connect from_op="Performance" from_port="example set" to_port="result 1"/>
<connect from_op="Performance" from_port="cluster model" to_port="result 2"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<connect from_op="Retrieve Engineering_majors1" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Normalize" to_port="example set input"/>
<connect from_op="Normalize" from_port="example set output" to_op="Loop Parameters" to_port="input 1"/>
<connect from_op="Loop Parameters" from_port="result 1" to_port="result 1"/>
<connect from_op="Loop Parameters" from_port="result 2" to_port="result 2"/>
</process>
</process>
