<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="concurrency:loop" compatibility="9.2.000" expanded="true" height="82" name="Loop" width="90" x="45" y="34"> <parameter key="number_of_iterations" value="5"/> <parameter key="iteration_macro" value="iterator"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="false"/> <process expanded="true"> <operator activated="true" class="generate_macro" compatibility="9.2.000" expanded="true" height="82" name="Generate Macro" width="90" x="45" y="34"> <list key="function_descriptions"> <parameter key="value" value="eval(%{iterator}) * 50"/> </list> </operator> <operator activated="true" class="print_to_console" compatibility="9.2.000" expanded="true" height="82" name="Print to Console" width="90" x="179" y="34"> <parameter key="log_value" value="%{value}"/> </operator> <connect from_port="input 1" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Print to Console" to_port="through 1"/> <connect from_op="Print to Console" from_port="through 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
