How to join automatically
Hi, I want to analyse the content of files. One per line and the other one by column because data are group together in that way. For now I transpose the first one twice, i split the two documents in fonction on their number of column for the first one, and his number of lines for the second one. I have to write manually the ration for the split (for ex 3*0.33 if their is 3 lines/ columns) I want this to be automatic.
Then I join the split files which have the same id.
Here is the code
Thank you really much
Here is the code
<?xml version="1.0" encoding="UTF-8"?><process version="8.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="8.2.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve" width="90" x="45" y="391"> <parameter key="repository_entry" value="//Local Repository/format_alarme_11"/> </operator> <operator activated="true" class="numerical_to_polynominal" compatibility="8.2.000" expanded="true" height="82" name="Numerical to Polynominal" width="90" x="45" y="493"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Conditions"/> </operator> <operator activated="true" class="split_data" compatibility="8.2.000" expanded="true" height="124" name="Split Data" width="90" x="45" y="595"> <enumeration key="partitions"> <parameter key="ratio" value="0.3333333333"/> <parameter key="ratio" value="0.3333333333"/> <parameter key="ratio" value="0.3333333333"/> </enumeration> </operator> <operator activated="true" class="nominal_to_text" compatibility="8.2.000" expanded="true" height="82" name="Nominal to Text" width="90" x="112" y="799"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Rule operators|Result IF TRUE|Result IF FALSE|Independent test?|Action if false"/> </operator> <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (4)" width="90" x="313" y="493"> <list key="function_descriptions"> <parameter key="test" value="[Checked variables]"/> </list> </operator> <operator activated="true" class="retrieve" compatibility="8.2.000" expanded="true" height="68" name="Retrieve (2)" width="90" x="45" y="187"> <parameter key="repository_entry" value="//Local Repository/Alarm 11 data"/> </operator> <operator activated="true" class="transpose" compatibility="8.2.000" expanded="true" height="82" name="Transpose" width="90" x="45" y="34"/> <operator activated="true" class="split_data" compatibility="8.2.000" expanded="true" height="124" name="Split Data (2)" width="90" x="112" y="238"> <enumeration key="partitions"> <parameter key="ratio" value="0.3333333333"/> <parameter key="ratio" value="0.3333333333"/> <parameter key="ratio" value="0.3333333333"/> </enumeration> </operator> <operator activated="true" class="extract_macro" compatibility="8.2.000" expanded="true" height="68" name="Extract Macro (3)" width="90" x="246" y="238"> <parameter key="macro" value="capteur_3"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="id"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="transpose" compatibility="8.2.000" expanded="true" height="82" name="Transpose (4)" width="90" x="380" y="340"/> <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (3)" width="90" x="581" y="289"> <list key="function_descriptions"> <parameter key="test" value="%{capteur_3}"/> </list> </operator> <operator activated="true" class="extract_macro" compatibility="8.2.000" expanded="true" height="68" name="Extract Macro (2)" width="90" x="246" y="136"> <parameter key="macro" value="capteur_2"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="id"/> <parameter key="example_index" value="2"/> <list key="additional_macros"/> </operator> <operator activated="true" class="transpose" compatibility="8.2.000" expanded="true" height="82" name="Transpose (3)" width="90" x="380" y="136"/> <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="447" y="136"> <list key="function_descriptions"> <parameter key="test" value="%{capteur_2}"/> </list> </operator> <operator activated="true" class="extract_macro" compatibility="8.2.000" expanded="true" height="68" name="Extract Macro" width="90" x="179" y="34"> <parameter key="macro" value="capteur_1"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="id"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="transpose" compatibility="8.2.000" expanded="true" height="82" name="Transpose (2)" width="90" x="313" y="34"/> <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes" width="90" x="514" y="34"> <list key="function_descriptions"> <parameter key="test" value="%{capteur_1}"/> </list> </operator> <operator activated="true" class="concurrency:join" compatibility="8.2.000" expanded="true" height="82" name="Join" width="90" x="514" y="391"> <parameter key="join_type" value="outer"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="test" value="test"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="8.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="715" y="340"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="test|id|att_1"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="8.2.000" expanded="true" height="82" name="Nominal to Text (2)" width="90" x="246" y="595"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Action if false|Independent test?|Result IF FALSE|Result IF TRUE|Rule operators"/> </operator> <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (5)" width="90" x="380" y="595"> <list key="function_descriptions"> <parameter key="test" value="[Checked variables]"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (6)" width="90" x="246" y="748"> <list key="function_descriptions"> <parameter key="test" value="[Checked variables]"/> </list> </operator> <operator activated="true" class="concurrency:join" compatibility="8.2.000" expanded="true" height="82" name="Join (2)" width="90" x="648" y="544"> <parameter key="join_type" value="outer"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="test" value="test"/> </list> </operator> <operator activated="true" class="concurrency:join" compatibility="8.2.000" expanded="true" height="82" name="Join (3)" width="90" x="514" y="799"> <parameter key="join_type" value="outer"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="test" value="test"/> </list> </operator> <operator activated="true" class="replace_missing_values" compatibility="8.2.000" expanded="true" height="103" name="Replace Missing Values" width="90" x="715" y="799"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Rule operators|Result IF TRUE|Result IF FALSE|Independent test?|Conditions|Action if false"/> <list key="columns"/> </operator> <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (7)" width="90" x="983" y="799"> <list key="function_descriptions"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="8.2.000" expanded="true" height="103" name="Replace Missing Values (2)" width="90" x="782" y="544"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Rule operators|Result IF TRUE|Result IF FALSE|Independent test?|Conditions|Action if false"/> <list key="columns"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="8.2.000" expanded="true" height="103" name="Replace Missing Values (3)" width="90" x="715" y="34"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Rule operators|Result IF TRUE|Result IF FALSE|Independent test?|Conditions|Action if false"/> <list key="columns"/> </operator> <operator activated="true" class="generate_attributes" compatibility="8.2.000" expanded="true" height="82" name="Generate Attributes (8)" width="90" x="849" y="34"> <list key="function_descriptions"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Numerical to Polynominal" to_port="example set input"/> <connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Split Data" to_port="example set"/> <connect from_op="Split Data" from_port="partition 1" to_op="Generate Attributes (4)" to_port="example set input"/> <connect from_op="Split Data" from_port="partition 2" to_op="Nominal to Text (2)" to_port="example set input"/> <connect from_op="Split Data" from_port="partition 3" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Generate Attributes (6)" to_port="example set input"/> <connect from_op="Generate Attributes (4)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Split Data (2)" to_port="example set"/> <connect from_op="Split Data (2)" from_port="partition 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="Split Data (2)" from_port="partition 2" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Split Data (2)" from_port="partition 3" to_op="Extract Macro (3)" to_port="example set"/> <connect from_op="Extract Macro (3)" from_port="example set" to_op="Transpose (4)" to_port="example set input"/> <connect from_op="Transpose (4)" from_port="example set output" to_op="Generate Attributes (3)" to_port="example set input"/> <connect from_op="Generate Attributes (3)" from_port="example set output" to_op="Join (2)" to_port="left"/> <connect from_op="Extract Macro (2)" from_port="example set" to_op="Transpose (3)" to_port="example set input"/> <connect from_op="Transpose (3)" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Join (3)" to_port="left"/> <connect from_op="Extract Macro" from_port="example set" to_op="Transpose (2)" to_port="example set input"/> <connect from_op="Transpose (2)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Replace Missing Values (3)" to_port="example set input"/> <connect from_op="Nominal to Text (2)" from_port="example set output" to_op="Generate Attributes (5)" to_port="example set input"/> <connect from_op="Generate Attributes (5)" from_port="example set output" to_op="Join (2)" to_port="right"/> <connect from_op="Generate Attributes (6)" from_port="example set output" to_op="Join (3)" to_port="right"/> <connect from_op="Join (2)" from_port="join" to_op="Replace Missing Values (2)" to_port="example set input"/> <connect from_op="Join (3)" from_port="join" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Generate Attributes (7)" to_port="example set input"/> <connect from_op="Generate Attributes (7)" from_port="example set output" to_port="result 3"/> <connect from_op="Replace Missing Values (2)" from_port="example set output" to_port="result 2"/> <connect from_op="Replace Missing Values (3)" from_port="example set output" to_op="Generate Attributes (8)" to_port="example set input"/> <connect from_op="Generate Attributes (8)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator> </process>
