🎉Community Raffle - Win $25
Join and Win
Support Vector Machine
User: "Flixport"
New Altair Community Member
Updated by Jocelyn
Hey guys,
the Random Forest works so far, I'm currently also trying the SVM (Support Vector Machine) as a countercheck. I have filled in a special attribute as Category here, but when I insert the operator Set Role, the SVM operator tells me that a special attribute is missing or insufficient capability. Of course I applied Nominal to Numerical, this requirement must be met. But as I just said, I can't get rid of the error message. As a help the SVM operator offers the "Set Role" operator, but now the svm operator shows me the that the capability is not enough :|
Thanks for the answers
BR
1 - 3 of 31
    User: "varunm1"
    Accepted Answer
     If you are trying to predict more than 2 classes then a regular SVM does not work. You can choose Support Vector Machine (LibSVM) for multiclass classification.
    User: "IngoRM"
    Accepted Answer
    This is actually desired behavior (so you can still see what the possible values are even if they do not occur in the current value - that is sometimes important).  There are a couple of ways to force the re-creation of the meta data for the new data, but my personal favorite is to use a Guess Types operator on that column after the filtering.  That will fix the value type to binominal and recreate the meta data.
    Hope this helps,
    Ingo
    User: "varunm1"
    Accepted Answer
    Hello @IngoRM
    Thanks for informing. That worked. @Flixport, please find the working process with regular SVM in the below process, I added guess types operator and selected Label in operator parameters.
    <?xml version="1.0" encoding="UTF-8"?><process version="9.2.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process">
    <parameter key="encoding" value="UTF-8"/>
    <process expanded="true">
    <operator activated="false" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve data_out_select_by_pca_weights" width="90" x="313" y="34">
    <parameter key="repository_entry" value="data/data_out_select_by_pca_weights"/>
    <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve data_out_pca" width="90" x="45" y="442">
    <parameter key="repository_entry" value="../OneDrive_1_4-9-2019/data_out_pca"/>
    <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve data_out_select_by_chisq_weights" width="90" x="45" y="187">
    <parameter key="repository_entry" value="../OneDrive_1_4-9-2019/data_out_select_by_chisq_weights"/>
    <operator activated="true" class="concurrency:join" compatibility="9.2.001" expanded="true" height="82" name="Join (2)" width="90" x="179" y="289">
    <parameter key="remove_double_attributes" value="true"/>
    <parameter key="join_type" value="inner"/>
    <parameter key="use_id_attribute_as_key" value="true"/>
    <list key="key_attributes"/>
    <parameter key="keep_both_join_attributes" value="false"/>
    <operator activated="true" class="multiply" compatibility="9.2.001" expanded="true" height="82" name="Multiply" width="90" x="313" y="289"/>
    <operator activated="true" class="filter_examples" compatibility="9.2.001" expanded="true" height="103" name="Filter Examples" width="90" x="514" y="289">
    <parameter key="parameter_expression" value=""/>
    <parameter key="condition_class" value="custom_filters"/>
    <parameter key="invert_filter" value="false"/>
    <list key="filters_list">
    <parameter key="filters_entry_key" value="Category.equals.financial"/>
    <parameter key="filters_entry_key" value="Category.equals.economic"/>
    </list>
    <parameter key="filters_logic_and" value="false"/>
    <parameter key="filters_check_metadata" value="true"/>
    <operator activated="true" class="guess_types" compatibility="9.2.001" expanded="true" height="82" name="Guess Types" width="90" x="648" y="289">
    <parameter key="attribute" value="Category"/>
    <parameter key="decimal_point_character" value="."/>
    <operator activated="true" class="set_role" compatibility="9.2.001" expanded="true" height="82" name="Set Role" width="90" x="782" y="289">
    <parameter key="attribute_name" value="Category"/>
    <operator activated="true" class="split_data" compatibility="9.2.001" expanded="true" height="103" name="Split Data" width="90" x="916" y="289">
    <enumeration key="partitions">
    <parameter key="ratio" value="0.8"/>
    <parameter key="ratio" value="0.2"/>
    </enumeration>
    <parameter key="sampling_type" value="shuffled sampling"/>
    <parameter key="use_local_random_seed" value="false"/>
    <parameter key="local_random_seed" value="1992"/>
    <operator activated="true" class="x_validation" compatibility="5.1.002" expanded="true" height="124" name="Validation" width="90" x="1050" y="85">
    <parameter key="create_complete_model" value="false"/>
    <parameter key="average_performances_only" value="true"/>
    <parameter key="leave_one_out" value="false"/>
    <parameter key="number_of_validations" value="5"/>
    <parameter key="sampling_type" value="2"/>
    <operator activated="true" class="support_vector_machine" compatibility="9.2.001" expanded="true" height="124" name="SVM" width="90" x="313" y="34">
    <parameter key="kernel_type" value="dot"/>
    <parameter key="kernel_gamma" value="1.0"/>
    <parameter key="kernel_sigma1" value="1.0"/>
    <parameter key="kernel_sigma2" value="0.0"/>
    <parameter key="kernel_sigma3" value="2.0"/>
    <parameter key="kernel_shift" value="1.0"/>
    <parameter key="kernel_degree" value="2.0"/>
    <parameter key="kernel_a" value="1.0"/>
    <parameter key="kernel_b" value="0.0"/>
    <parameter key="kernel_cache" value="200"/>
    <parameter key="C" value="0.0"/>
    <parameter key="convergence_epsilon" value="0.001"/>
    <parameter key="max_iterations" value="100000"/>
    <parameter key="scale" value="true"/>
    <parameter key="calculate_weights" value="true"/>
    <parameter key="return_optimization_performance" value="true"/>
    <parameter key="L_pos" value="1.0"/>
    <parameter key="L_neg" value="1.0"/>
    <parameter key="epsilon" value="0.0"/>
    <parameter key="epsilon_plus" value="0.0"/>
    <parameter key="epsilon_minus" value="0.0"/>
    <parameter key="balance_cost" value="false"/>
    <parameter key="quadratic_loss_pos" value="false"/>
    <parameter key="quadratic_loss_neg" value="false"/>
    <parameter key="estimate_performance" value="false"/>
    <connect from_port="training" to_op="SVM" to_port="training set"/>
    <connect from_op="SVM" from_port="model" to_port="model"/>
    <portSpacing port="source_training" spacing="0"/>
    </process>
    <operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model" width="90" x="112" y="34">
    <parameter key="create_view" value="false"/>
    <operator activated="true" class="performance" compatibility="9.2.001" expanded="true" height="82" name="Performance" width="90" x="246" y="136">
    <parameter key="use_example_weights" value="true"/>
    <connect from_port="model" to_op="Apply Model" to_port="model"/>
    <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
    <connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
    <portSpacing port="sink_averagable 1" spacing="0"/>
    <portSpacing port="sink_averagable 2" spacing="0"/>
    </process>
    <description align="center" color="transparent" colored="false" width="126">A cross-validation evaluating a decision tree model.</description>
    <operator activated="true" class="apply_model" compatibility="9.2.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="1184" y="289">
    <operator activated="true" class="performance_classification" compatibility="9.2.001" expanded="true" height="82" name="Performance (2)" width="90" x="1318" y="391">
    <parameter key="main_criterion" value="first"/>
    <parameter key="accuracy" value="true"/>
    <parameter key="classification_error" value="false"/>
    <parameter key="kappa" value="false"/>
    <parameter key="weighted_mean_recall" value="false"/>
    <parameter key="weighted_mean_precision" value="false"/>
    <parameter key="spearman_rho" value="false"/>
    <parameter key="kendall_tau" value="false"/>
    <parameter key="absolute_error" value="false"/>
    <parameter key="relative_error" value="false"/>
    <parameter key="relative_error_lenient" value="false"/>
    <parameter key="relative_error_strict" value="false"/>
    <parameter key="normalized_absolute_error" value="false"/>
    <parameter key="root_mean_squared_error" value="false"/>
    <parameter key="root_relative_squared_error" value="false"/>
    <parameter key="squared_error" value="false"/>
    <parameter key="correlation" value="false"/>
    <parameter key="squared_correlation" value="false"/>
    <parameter key="cross-entropy" value="false"/>
    <parameter key="margin" value="false"/>
    <parameter key="soft_margin_loss" value="false"/>
    <parameter key="logistic_loss" value="false"/>
    <parameter key="skip_undefined_labels" value="true"/>
    <list key="class_weights"/>
    <connect from_op="Retrieve data_out_pca" from_port="output" to_op="Join (2)" to_port="right"/>
    <connect from_op="Retrieve data_out_select_by_chisq_weights" from_port="output" to_op="Join (2)" to_port="left"/>
    <connect from_op="Join (2)" from_port="join" to_op="Multiply" to_port="input"/>
    <connect from_op="Multiply" from_port="output 1" to_op="Filter Examples" to_port="example set input"/>
    <connect from_op="Filter Examples" from_port="example set output" to_op="Guess Types" to_port="example set input"/>
    <connect from_op="Guess Types" from_port="example set output" to_op="Set Role" to_port="example set input"/>
    <connect from_op="Set Role" from_port="example set output" to_op="Split Data" to_port="example set"/>
    <connect from_op="Split Data" from_port="partition 1" to_op="Validation" to_port="training"/>
    <connect from_op="Split Data" from_port="partition 2" to_op="Apply Model (2)" to_port="unlabelled data"/>
    <connect from_op="Validation" from_port="model" to_op="Apply Model (2)" to_port="model"/>
    <connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
    <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
    <connect from_op="Performance (2)" from_port="performance" to_port="result 1"/>
    <description align="left" color="yellow" colored="false" height="139" resized="true" width="565" x="11" y="618">MODEL&lt;br/&gt;&lt;br/&gt;Beispiel Anwendung:&lt;br&gt;b. In diesem Beispiel wurde Feld &amp;quot;Topics&amp;quot; als Zielvariable benutzt. Baue ein Model um die restliche Datens&amp;#228;tze zu klassifizieren. Wie sieht die Pr&amp;#228;zision aus?</description>
    </process>
    </process>
    Thanks
