<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve Titanic Training" width="90" x="246" y="289"> <parameter key="repository_entry" value="//Samples/data/Titanic Training"/> </operator> <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve Titanic Unlabeled" width="90" x="112" y="85"> <parameter key="repository_entry" value="//Samples/data/Titanic Unlabeled"/> </operator> <operator activated="true" class="sample" compatibility="9.2.001" expanded="true" height="82" name="Sample" width="90" x="246" y="85"> <parameter key="sample" value="absolute"/> <parameter key="balance_data" value="false"/> <parameter key="sample_size" value="5"/> <parameter key="sample_ratio" value="0.1"/> <parameter key="sample_probability" value="0.1"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"/> <list key="sample_probability_per_class"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <description align="center" color="transparent" colored="false" width="126">select random 5 request samples</description> </operator> <operator activated="true" class="cross_distances" compatibility="9.2.001" expanded="true" height="103" name="Cross Distances" origin="GENERATED_TUTORIAL" width="90" x="447" y="136"> <parameter key="measure_types" value="MixedMeasures"/> <parameter key="mixed_measure" value="MixedEuclideanDistance"/> <parameter key="nominal_measure" value="NominalDistance"/> <parameter key="numerical_measure" value="KernelEuclideanDistance"/> <parameter key="divergence" value="GeneralizedIDivergence"/> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="1.0"/> <parameter key="kernel_sigma1" value="1.0"/> <parameter key="kernel_sigma2" value="0.0"/> <parameter key="kernel_sigma3" value="2.0"/> <parameter key="kernel_degree" value="3.0"/> <parameter key="kernel_shift" value="1.0"/> <parameter key="kernel_a" value="1.0"/> <parameter key="kernel_b" value="0.0"/> <parameter key="only_top_k" value="false"/> <parameter key="k" value="10"/> <parameter key="search_for" value="nearest"/> <parameter key="compute_similarities" value="false"/> <description align="center" color="transparent" colored="false" width="126">request ID linked to the reference document ID, to view the nearest neighboors, sort by increasing distance</description> </operator> <operator activated="true" class="sort" compatibility="9.2.001" expanded="true" height="82" name="Sort" width="90" x="581" y="136"> <parameter key="attribute_name" value="distance"/> <parameter key="sorting_direction" value="increasing"/> </operator> <operator activated="true" class="sort" compatibility="9.2.001" expanded="true" height="82" name="Sort (2)" width="90" x="715" y="136"> <parameter key="attribute_name" value="request"/> <parameter key="sorting_direction" value="increasing"/> </operator> <connect from_op="Retrieve Titanic Training" from_port="output" to_op="Cross Distances" to_port="reference set"/> <connect from_op="Retrieve Titanic Unlabeled" from_port="output" to_op="Sample" to_port="example set input"/> <connect from_op="Sample" from_port="example set output" to_op="Cross Distances" to_port="request set"/> <connect from_op="Cross Distances" from_port="result set" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Sort (2)" to_port="example set input"/> <connect from_op="Sort (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
