Automatically run a process
Prentice
Is it possible to automatically run a process, without using RapidMiner Server?
As in use a code to open RapidMiner, run the preferred process and close it?
And is it possible to 'paste' the results from a process in an existing Excel file in a certain cell without using Advanced Reporting Extension?
Thanks
-Prentice
Excel
Automation
varunm1
Hi
@Prentice
I tried to find the solution for the same question, but I don't think there is anything to run process automatically without server as the jobs are not scheduled in any other way in RM.
@sgenzer
are there any suggestions from your end?
Thanks
varunm1
Hi
@Prentice
@sgenzer
Thanks
MartinLiebig
why no tserver? It's free for academics.
Best,
Martin
Prentice
@varunm1
, ah ok. Thanks anyway.
@mschmitz
, the reason that I don't want tserver is because the end product is for non-academic users and purchasing tserver especially for this is a bit expensive.
sgenzer
@Prentice
@varunm1
no, I don't know of a documented method to execute RM Studio processes automatically (e.g. on a CRON job).
Honestly if you use the
RM Server PAYG solution on AWS
or Azure, the cost is very, very reasonable. How long does your process take to execute? Say it takes 5 min and you run it every day (I used to have a client who was in this exact use case). PAYG costs $7.05/hour which is $0.12/minute. Say it takes a total of 10 min for the server to boot, run the process, log the results, and shut down. That's $1.20 per execution or around $36/month assuming you execute 1x/day. If your client is not getting more than $36/month of business value out of your process, I cannot imagine why you're deploying it in the first place.
Remember the cost of deployment includes the development and maintenance of the solution. In my experience, code-based solutions may look cheap (free?) on the surface but there are many, many hidden costs under the hood. Packaged solutions like RapidMiner will look more expensive on the outside but there are no hidden "oh crap my code is broken and the coder is gone and I don't understand his spaghetti code so now I have to hire a new coder to figure this all out..." costs.
Scott
BalazsBaranyRM
there is actually a semi-documented and semi-supported way to execute RM processes on the command line.
Check out the scripts folder in your RapidMiner installation. You'll find rapidminer-batch.sh and rapidminer-batch.bat here, select the one matching your operating system.
It's a bit of a challenge to get it to execute the process if it has spaces in the path (including "Local Repository"). The following syntax worked for me on Linux:
scripts/rapidminer-batch.sh '//Local\ Repository/processes/community/Test\ Iris'
The backslash quotes the following character, here the space. The process was executed correctly but it takes almost as long as starting Studio and running the process there.
Check out the short help text of this script by calling it without parameters. It can also execute a file (not a repository entry), and you can even set macro values on the command line.
Balázs
varunm1
Thanks, Scott, I agree with what you said, there are many factors in play when pricing a product.
@BalazsBarany
thanks. This is what I am looking for. I can use RM server for free (academic) but want to find any other ways to do this, pure curiosity.
