<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Labor-Negotiations" origin="GENERATED_TUTORIAL" width="90" x="179" y="120"> <parameter key="repository_entry" value="//Samples/data/Labor-Negotiations"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="9.2.001" expanded="true" height="82" name="Generate Concatenation" origin="GENERATED_TUTORIAL" width="90" x="380" y="120"> <parameter key="first_attribute" value="vacation"/> <parameter key="second_attribute" value="statutory-holidays"/> <parameter key="separator" value="_"/> <parameter key="trim_values" value="false"/> </operator> <operator activated="true" class="replace" compatibility="9.2.001" expanded="true" height="82" name="Replace" width="90" x="581" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="vacation_statutory-holidays"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="_"/> </operator> <connect from_op="Labor-Negotiations" from_port="output" to_op="Generate Concatenation" to_port="example set input"/> <connect from_op="Generate Concatenation" from_port="example set output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="generate_sales_data" compatibility="9.2.001" expanded="true" height="68" name="Generate Sales Data" width="90" x="246" y="34"> <parameter key="number_examples" value="100"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="date_to_numerical" compatibility="9.2.001" expanded="true" height="82" name="Date to Numerical" width="90" x="380" y="34"> <parameter key="attribute_name" value="date"/> <parameter key="time_unit" value="year"/> <parameter key="millisecond_relative_to" value="second"/> <parameter key="second_relative_to" value="minute"/> <parameter key="minute_relative_to" value="hour"/> <parameter key="hour_relative_to" value="day"/> <parameter key="day_relative_to" value="month"/> <parameter key="week_relative_to" value="year"/> <parameter key="month_relative_to" value="year"/> <parameter key="quarter_relative_to" value="year"/> <parameter key="half_year_relative_to" value="year"/> <parameter key="year_relative_to" value="era"/> <parameter key="keep_old_attribute" value="true"/> <description align="center" color="transparent" colored="false" width="126">get year</description> </operator> <operator activated="true" class="date_to_numerical" compatibility="9.2.001" expanded="true" height="82" name="Date to Numerical (2)" width="90" x="514" y="34"> <parameter key="attribute_name" value="date"/> <parameter key="time_unit" value="month"/> <parameter key="millisecond_relative_to" value="second"/> <parameter key="second_relative_to" value="minute"/> <parameter key="minute_relative_to" value="hour"/> <parameter key="hour_relative_to" value="day"/> <parameter key="day_relative_to" value="month"/> <parameter key="week_relative_to" value="year"/> <parameter key="month_relative_to" value="year"/> <parameter key="quarter_relative_to" value="year"/> <parameter key="half_year_relative_to" value="year"/> <parameter key="year_relative_to" value="era"/> <parameter key="keep_old_attribute" value="true"/> <description align="center" color="transparent" colored="false" width="126">get month</description> </operator> <operator activated="true" class="select_attributes" compatibility="9.2.001" expanded="true" height="82" name="Select Attributes" width="90" x="648" y="34"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="date|date_year|date_month"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.2.001" expanded="true" height="82" name="Generate Attributes" width="90" x="782" y="34"> <list key="function_descriptions"> <parameter key="New_YearMo" value="concat(str(date_year),suffix(concat("0",str(date_month)),2))"/> </list> <parameter key="keep_all" value="true"/> <description align="center" color="transparent" colored="false" width="126">concatenate year and month</description> </operator> <operator activated="true" class="parse_numbers" compatibility="9.2.001" expanded="true" height="82" name="Parse Numbers" width="90" x="916" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="unparsable_value_handling" value="fail"/> <description align="center" color="transparent" colored="false" width="126">convert nominal to numerical</description> </operator> <connect from_op="Generate Sales Data" from_port="output" to_op="Date to Numerical" to_port="example set input"/> <connect from_op="Date to Numerical" from_port="example set output" to_op="Date to Numerical (2)" to_port="example set input"/> <connect from_op="Date to Numerical (2)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
