<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="facebook:FindPageContent" compatibility="1.0.005" expanded="true" height="68" name="Find Page Content" width="90" x="45" y="136">
<parameter key="Page ID" value="jagadiri.id"/>
<parameter key="FB Connection" value="Facebook"/>
<operator activated="true" class="concurrency:loop_values" compatibility="9.2.001" expanded="true" height="103" name="Loop Values" width="90" x="179" y="187">
<parameter key="attribute" value="Post ID"/>
<parameter key="iteration_macro" value="loop_value"/>
<parameter key="reuse_results" value="false"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="facebook:FindReactions" compatibility="1.0.005" expanded="true" height="68" name="Find Reactions" width="90" x="45" y="34">
<parameter key="Post ID" value="%{loop_value}"/>
<operator activated="true" class="facebook:FindComments" compatibility="1.0.005" expanded="true" height="68" name="Find Comments" width="90" x="45" y="136">
<parameter key="Comment ID" value="%{loop_value}"/>
<connect from_port="input 1" to_op="Find Reactions" to_port="example set"/>
<connect from_port="input 2" to_op="Find Comments" to_port="example set"/>
<connect from_op="Find Reactions" from_port="example set" to_port="output 1"/>
<connect from_op="Find Comments" from_port="example set" to_port="output 2"/>
<portSpacing port="source_input 3" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
<portSpacing port="sink_output 3" spacing="0"/>
</process>
<connect from_op="Find Page Content" from_port="example set" to_op="Loop Values" to_port="input 1"/>
<connect from_op="Loop Values" from_port="output 1" to_port="result 1"/>
</process>
</process>
Hi Rapidminer users,
I tried to use facebook extension to extract data from facebook. I notice there is 4 operators in the extension. However there is no example in there. i try it all and only 2 of it success, which is Find Page Content and Find Reactions. Can someone give an example on how to use these operators?
