I can't launch the RapidMiner (Errorcode: 1)
misoo12
New Altair Community Member
After updating the RapidMiner, I saw the above message and couldn't launch the RapidMiner.
So I uninstalled both the program and the extension folder.
However, I saw the same message.
I found the same questions that some user saw the "Errorcode:1",
and Rapidminer's developer replied that we should check the program requirements.
My computer's environment is described below:
OS: Window 7 64bit
Processor: Inter i7 4.0 GHz (Quad core)
RAM: 16GB
Ver of JAVA: 1.8.0_191
I think that my environment is satisfied with system requirements.
What is the problem?
Best Answer
I cannot attach the image file in Explore.
I also try to upload the image in Google, but there is a continual message such as "You have to be around for a little while longer before you can post links."
So I share the image link.
https://github.com/MisooKim/misookim.github.io/blob/master/1.png
I am sorry. I solved the problem.
This error was occurred by lack of memory in my computer because some programs based on Java was executing in the background.
But I will leave this question for those who are facing the same problem.
Thank you for providing good software.
1 -
Hi! I have the same problem and I launched it on the Rapidminer-Studio.bat and it still didn't launch. The picture attached is what it showed. Take note also that while reinstalling the program some files was not read by the computer.
0 -
Execution on EDT has failed.
hmm cc @Marco_Boeck ??0 -
This sounds like the installation got messed up.
Please delete the entire C:\Program Files\RapidMiner\RapidMiner Studio folder (there must be nothing left), then install RapidMiner Studio again.
Marco2
