Had install Rapid Miner Server in a Windows Machine and had use it before, but had some network issues that were solve. So I could access the machine from my local work station. The machine where I had install Rapid Miner Server was restart it and now the service is not launch. Keep sending the following message:
"JBAS014777: Services which failed to start: service jboss.remoting.server
.remoting-connector: org.jboss.msc.service.StartException in service jboss.remot
ing.server.remoting-connector: JBAS017112: Address already in use: bind 0.0.0.0:
4447
service jboss.web.connector.http: org.jboss.msc.service.StartException in
service jboss.web.connector.http: JBAS018007: Error starting web connector
service jboss.remoting.server.management: org.jboss.msc.service.StartExcep
tion in service jboss.remoting.server.management: JBAS017112: Address already in
use: bind XX.XX.XX.XXX:9999
service jboss.serverManagement.controller.management.http: org.jboss.msc.s
ervice.StartException in service jboss.serverManagement.controller.management.ht
tp: Address already in use: bind RapidMinerServer/XX.XX.XX.XXX:9990"
I didn't made any change. If you can help.
Thanks in advance.
Cheers,
José
