<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000"> <context> <input/> <output/> <macros> <macro> <key>user_input_N</key> <value>99</value> </macro> </macros> </context> <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="9.2.000" expanded="true" height="82" name="Generate data" width="90" x="45" y="136"> <process expanded="true"> <operator activated="true" class="generate_sales_data" compatibility="9.2.000" expanded="true" height="68" name="Generate Sales Data" width="90" x="45" y="34"> <parameter key="number_examples" value="1000"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.2.000" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="34"> <list key="function_descriptions"> <parameter key="Total_Price" value="amount * single_price"/> </list> <parameter key="keep_all" value="true"/> <description align="center" color="transparent" colored="false" width="126">generate total price = single price * amount</description> </operator> <operator activated="true" class="aggregate" compatibility="8.2.000" expanded="true" height="82" name="Aggregate" width="90" x="313" y="34"> <parameter key="use_default_aggregation" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default_aggregation_function" value="average"/> <list key="aggregation_attributes"> <parameter key="Total_Price" value="sum"/> </list> <parameter key="group_by_attributes" value="customer_id"/> <parameter key="count_all_combinations" value="false"/> <parameter key="only_distinct" value="false"/> <parameter key="ignore_missings" value="true"/> <description align="center" color="transparent" colored="false" width="126">aggregate to get total price by customer</description> </operator> <operator activated="true" class="rename" compatibility="9.2.000" expanded="true" height="82" name="Rename (2)" width="90" x="514" y="34"> <parameter key="old_name" value="sum(Total_Price)"/> <parameter key="new_name" value="Total Expenses"/> <list key="rename_additional_attributes"/> </operator> <connect from_op="Generate Sales Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <description align="center" color="transparent" colored="false" width="126">simulate some sales data, say total expenses as customer life time value (LTV)</description> </operator> <operator activated="true" breakpoints="after" class="discretize_by_frequency" compatibility="9.2.000" expanded="true" height="103" name="Discretize" width="90" x="246" y="136"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Total Expenses"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="use_sqrt_of_examples" value="false"/> <parameter key="number_of_bins" value="100"/> <parameter key="range_name_type" value="long"/> <parameter key="automatic_number_of_digits" value="true"/> <parameter key="number_of_digits" value="-1"/> <description align="center" color="transparent" colored="false" width="126">cut the expenses into 100 bins</description> </operator> <operator activated="true" class="subprocess" compatibility="9.2.000" expanded="true" height="103" name="post processing" width="90" x="447" y="136"> <process expanded="true"> <operator activated="true" class="rename" compatibility="9.2.000" expanded="true" height="82" name="Rename" width="90" x="179" y="34"> <parameter key="old_name" value="Total Expenses"/> <parameter key="new_name" value="Range of Expenses"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="concurrency:join" compatibility="9.2.000" expanded="true" height="82" name="Join (2)" width="90" x="179" y="136"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="inner"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="customer_id" value="customer_id"/> </list> <parameter key="keep_both_join_attributes" value="false"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.2.000" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="380" y="34"> <list key="function_descriptions"> <parameter key="Percentile_bucket" value="parse(cut([Range of Expenses],5,index([Range of Expenses],"[")-5))"/> </list> <parameter key="keep_all" value="true"/> <description align="center" color="transparent" colored="false" width="126">get the range number, and the cut off by parsing the discretized results</description> </operator> <operator activated="true" class="filter_examples" compatibility="9.2.000" expanded="true" height="103" name="Filter Examples" width="90" x="581" y="34"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="custom_filters"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"> <parameter key="filters_entry_key" value="Percentile_bucket.eq.%{user_input_N}"/> </list> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="false"/> <description align="center" color="transparent" colored="false" width="126">find the corresponding subset in nth percentile bucket</description> </operator> <operator activated="true" class="sort" compatibility="9.2.000" expanded="true" height="82" name="Sort (2)" width="90" x="849" y="34"> <parameter key="attribute_name" value="Total Expenses"/> <parameter key="sorting_direction" value="increasing"/> <description align="center" color="transparent" colored="false" width="126">get the cutoff point between the nth and (n+1)th percentile</description> </operator> <operator activated="true" class="sort" compatibility="9.2.000" expanded="true" height="82" name="Sort" width="90" x="849" y="238"> <parameter key="attribute_name" value="Total Expenses"/> <parameter key="sorting_direction" value="decreasing"/> <description align="center" color="transparent" colored="false" width="126"/> </operator> <connect from_port="in 1" to_op="Rename" to_port="example set input"/> <connect from_port="in 2" to_op="Join (2)" to_port="right"/> <connect from_op="Rename" from_port="example set output" to_op="Join (2)" to_port="left"/> <connect from_op="Join (2)" from_port="join" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Sort (2)" to_port="example set input"/> <connect from_op="Filter Examples" from_port="original" to_op="Sort" to_port="example set input"/> <connect from_op="Sort (2)" from_port="example set output" to_port="out 1"/> <connect from_op="Sort" from_port="example set output" to_port="out 2"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="source_in 3" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <portSpacing port="sink_out 3" spacing="0"/> </process> </operator> <operator activated="true" class="extract_macro" compatibility="9.2.000" expanded="true" height="68" name="Extract Macro" width="90" x="648" y="136"> <parameter key="macro" value="%{user_input_N}th_percentile"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="Total Expenses"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> <description align="center" color="transparent" colored="false" width="126">extract the n-th percentile and store it into a macro variable</description> </operator> <connect from_op="Generate data" from_port="out 1" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="post processing" to_port="in 1"/> <connect from_op="Discretize" from_port="original" to_op="post processing" to_port="in 2"/> <connect from_op="post processing" from_port="out 1" to_op="Extract Macro" to_port="example set"/> <connect from_op="post processing" from_port="out 2" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="126"/> <portSpacing port="sink_result 2" spacing="0"/> <description align="center" color="yellow" colored="false" height="98" resized="true" width="901" x="10" y="10">User input: n (defined in context view)<br>for calculating the n-th percentile in the given data<br>This can also be used for anomaly detection (at least for 1D Interquartile range method)</description> </process> </operator> </process>
