<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Root" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.2.000" expanded="true" height="68" name="Ripley-Set" origin="GENERATED_TUTORIAL" width="90" x="112" y="34"> <parameter key="repository_entry" value="//Samples/data/Ripley-Set"/> </operator> <operator activated="true" class="top_down_clustering" compatibility="9.2.000" expanded="true" height="82" name="Top Down Clustering" origin="GENERATED_TUTORIAL" width="90" x="313" y="238"> <parameter key="create_cluster_label" value="true"/> <parameter key="max_depth" value="5"/> <parameter key="max_leaf_size" value="20"/> <process expanded="true"> <operator activated="true" class="concurrency:k_means" compatibility="9.0.001" expanded="true" height="82" name="K-Means" origin="GENERATED_TUTORIAL" width="90" x="246" y="30"> <parameter key="add_cluster_attribute" value="true"/> <parameter key="add_as_label" value="false"/> <parameter key="remove_unlabeled" value="false"/> <parameter key="k" value="3"/> <parameter key="max_runs" value="10"/> <parameter key="determine_good_start_values" value="false"/> <parameter key="measure_types" value="BregmanDivergences"/> <parameter key="mixed_measure" value="MixedEuclideanDistance"/> <parameter key="nominal_measure" value="NominalDistance"/> <parameter key="numerical_measure" value="EuclideanDistance"/> <parameter key="divergence" value="SquaredEuclideanDistance"/> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="1.0"/> <parameter key="kernel_sigma1" value="1.0"/> <parameter key="kernel_sigma2" value="0.0"/> <parameter key="kernel_sigma3" value="2.0"/> <parameter key="kernel_degree" value="3.0"/> <parameter key="kernel_shift" value="1.0"/> <parameter key="kernel_a" value="1.0"/> <parameter key="kernel_b" value="0.0"/> <parameter key="max_optimization_steps" value="100"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <connect from_port="example set" to_op="K-Means" to_port="example set"/> <connect from_op="K-Means" from_port="cluster model" to_port="cluster model"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_cluster model" spacing="0"/> </process> </operator> <operator activated="true" class="multiply" compatibility="9.2.000" expanded="true" height="103" name="Multiply" width="90" x="514" y="34"/> <operator activated="true" class="flatten_clustering" compatibility="9.2.000" expanded="true" height="82" name="Flatten Clustering" width="90" x="648" y="238"> <parameter key="number_of_clusters" value="3"/> <parameter key="add_as_label" value="true"/> <parameter key="remove_unlabeled" value="false"/> </operator> <connect from_op="Ripley-Set" from_port="output" to_op="Top Down Clustering" to_port="example set"/> <connect from_op="Top Down Clustering" from_port="cluster model" to_op="Multiply" to_port="input"/> <connect from_op="Top Down Clustering" from_port="clustered set" to_op="Flatten Clustering" to_port="example set"/> <connect from_op="Multiply" from_port="output 1" to_port="result 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Flatten Clustering" to_port="hierarchical"/> <connect from_op="Flatten Clustering" from_port="example set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
