<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="9.2.000" expanded="true" height="68" name="Read CSV" width="90" x="112" y="34"> <parameter key="csv_file" value="C:\Users\Lionel\Downloads\12Abstracts.csv"/> <parameter key="column_separators" value=";"/> <parameter key="trim_lines" value="false"/> <parameter key="use_quotes" value="true"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character" value="\"/> <parameter key="skip_comments" value="true"/> <parameter key="comment_characters" value="#"/> <parameter key="starting_row" value="1"/> <parameter key="parse_numbers" value="true"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="date_format" value=""/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="encoding" value="windows-1252"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="DOI.true.polynominal.attribute"/> <parameter key="1" value="Link.true.polynominal.attribute"/> <parameter key="2" value="Abstract.true.polynominal.attribute"/> <parameter key="3" value="Sample Size.true.integer.attribute"/> <parameter key="4" value="Students?.true.polynominal.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="text:generate_extract" compatibility="8.1.000" expanded="true" height="68" name="Generate Extract" width="90" x="246" y="34"> <parameter key="source_attribute" value="Abstract"/> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <parameter key="attribute_type" value="Nominal"/> <list key="regular_expression_queries"> <parameter key="Sample_size" value="(\d{3}(?=[^s^\d]))|(\d{3}(?=[^s^\d]))"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <parameter key="ignore_CDATA" value="true"/> <parameter key="assume_html" value="true"/> <list key="index_queries"/> <list key="jsonpath_queries"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Generate Extract" to_port="Example Set"/> <connect from_op="Generate Extract" from_port="Example Set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
