"Why am i getting this error message while using a Late 2011 MacBook Pro Model?"
Process: java [9994]
Path: /usr/bin/java
Identifier: com.rapidminer.studio
Version: 1.0 (1.0)
Code Type: X86-64 (Native)
Parent Process: bash [9983]
PlugIn Path: /Volumes/VOLUME/RapidMiner Studio.app/Contents/PlugIns/jre_1.8.0_XX.jre/Contents/Home/lib/libawt_lwawt.dylib
PlugIn Identifier: libawt_lwawt.dylib
PlugIn Version: ??? (???)
Date/Time: 2019-01-31 18:42:27.683 -0500
OS Version: Mac OS X 10.7.5 (11G63)
Report Version: 9
Interval Since Last Report: 8283773 sec
Crashes Since Last Report: 42
Per-App Interval Since Last Report: 1658 sec
Per-App Crashes Since Last Report: 8
Anonymous UUID: 8063322C-81CF-4623-90C3-314A8B4A4D3A
Crashed Thread: 2
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
objc[9994]: garbage collection is OFF
Dyld Error Message:
Symbol not found: _CTFontCopyDefaultCascadeListForLanguages
Referenced from: /Volumes/VOLUME/RapidMiner Studio.app/Contents/PlugIns/jre_1.8.0_XX.jre/Contents/Home/lib/libawt_lwawt.dylib
Expected in: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
VM Region Summary:
ReadOnly portion of Libraries: Total=176.1M resident=83.1M(47%) swapped_out_or_unallocated=92.9M(53%)
Writable regions: Total=6.4G written=3.2G(50%) resident=3.4G(53%) swapped_out=1436K(0%) unallocated=3.0G(47%)
REGION TYPE VIRTUAL
(null) (reserved) 2.1G reserved VM address space (unallocated)
ATS (font support) 31.9M
ATS (font support) (reserved) 4K reserved VM address space (unallocated)
CG backing stores 12.6M
CG image 1456K
CG raster data 64K
CG shared images 4536K
CoreAnimation 20K
CoreGraphics 16K
CoreImage 8K
CoreServices 5776K
IOKit 53.4M
MALLOC 183.7M
MALLOC guard page 64K
Memory tag=240 4K
Memory tag=242 12K
OpenCL 20K
OpenGL GLSL 1024K
STACK GUARD 56.2M
Stack 60.9M
Stack (reserved) 520K reserved VM address space (unallocated)
VM_ALLOCATE 5.5G
__CI_BITMAP 80K
__DATA 14.2M
__IMAGE 528K
__LINKEDIT 57.8M
__TEXT 118.3M
__UNICODE 544K
mapped file 966.0M
shared memory 29.4M
TOTAL 9.1G
TOTAL, minus reserved VM space 7.1G
Model: MacBookPro8,1, BootROM MBP81.0047.B27, 2 processors, Intel Core i5, 2.4 GHz, 8 GB, SMC 1.68f99
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333531533642465238432D48392020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.198.19.22)
Bluetooth: Version 4.0.8f17, 2 service, 11 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: TOSHIBA MK7559GSXF, 750.16 GB
Serial ATA Device: MATSHITADVD-R UJ-8A8
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 3
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfa100000 / 2
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0xfa120000 / 5
USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 7
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0xfd100000 / 2
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
