I am storing cross validation predictions using Write Excel. I see that the output samples (570553) of Cross validation 5 fold for Gradient Boosted Tree are more than input samples (316974). I am not sure if I am doing something wrong. Please see XML below.
<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.1.000" expanded="true" height="68" name="Retrieve Assistment_Data_Labels" width="90" x="45" y="85">
<parameter key="repository_entry" value="../../data/AIED_New/Assistment_Data_Labels"/>
<operator activated="true" class="multiply" compatibility="9.1.000" expanded="true" height="124" name="Multiply (6)" width="90" x="179" y="85"/>
<operator activated="true" class="select_attributes" compatibility="9.1.000" expanded="true" height="82" name="Select Attributes (3)" width="90" x="380" y="442">
<parameter key="attribute" value=""/>
<parameter key="attributes" value="Ln|Ln-1|NumActions|RES_BORED|RES_CONFUSED|RES_FRUSTRATED|RES_GAMING|RES_OFFTASK|attemptCount|correct|endsWithScaffolding|frIsHelpRequest|frIsHelpRequestScaffolding|frPast5HelpRequest|frPast5WrongCount|frPast8HelpRequest|frPast8WrongCount|frTotalSkillOpportunitiesScaffolding|hint|hintCount|hintTotal|manywrong|original|past8BottomOut|problemType|scaffold|skill|sumRight|sumTimePerSkill|timeGreater10SecAndNextActionRight|timeSinceSkill|timeTaken|totalFrAttempted|totalFrPastWrongCount|totalFrPercentPastWrong|totalFrSkillOpportunities|totalFrSkillOpportunitiesByScaffolding|totalFrTimeOnSkill|totalTimeByPercentCorrectForskill"/>
<operator activated="true" class="concurrency:cross_validation" compatibility="9.1.000" expanded="true" height="166" name="Cross Validation (4)" width="90" x="581" y="442">
<parameter key="split_on_batch_attribute" value="false"/>
<parameter key="leave_one_out" value="false"/>
<parameter key="number_of_folds" value="5"/>
<parameter key="sampling_type" value="automatic"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="h2o:gradient_boosted_trees" compatibility="9.0.000" expanded="true" height="103" name="Gradient Boosted Trees (3)" width="90" x="112" y="34">
<parameter key="number_of_trees" value="20"/>
<parameter key="reproducible" value="false"/>
<parameter key="maximum_number_of_threads" value="4"/>
<parameter key="maximal_depth" value="20"/>
<parameter key="min_rows" value="10.0"/>
<parameter key="min_split_improvement" value="0.0"/>
<parameter key="number_of_bins" value="20"/>
<parameter key="learning_rate" value="0.1"/>
<parameter key="sample_rate" value="1.0"/>
<parameter key="distribution" value="AUTO"/>
<parameter key="early_stopping" value="false"/>
<parameter key="stopping_rounds" value="1"/>
<parameter key="stopping_metric" value="AUTO"/>
<parameter key="stopping_tolerance" value="0.001"/>
<parameter key="max_runtime_seconds" value="0"/>
<list key="expert_parameters"/>
<connect from_port="training set" to_op="Gradient Boosted Trees (3)" to_port="training set"/>
<connect from_op="Gradient Boosted Trees (3)" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.1.000" expanded="true" height="82" name="Apply Model (4)" width="90" x="45" y="34">
<parameter key="create_view" value="false"/>
<operator activated="true" class="multiply" compatibility="9.1.000" expanded="true" height="103" name="Multiply (3)" width="90" x="45" y="136"/>
<operator activated="true" class="performance" compatibility="9.1.000" expanded="true" height="82" name="Performance (3)" width="90" x="246" y="340">
<parameter key="use_example_weights" value="true"/>
<operator activated="true" class="performance_classification" compatibility="9.1.000" expanded="true" height="82" name="Performance (4)" width="90" x="246" y="238">
<parameter key="main_criterion" value="first"/>
<parameter key="accuracy" value="true"/>
<parameter key="classification_error" value="false"/>
<parameter key="kappa" value="true"/>
<parameter key="weighted_mean_recall" value="false"/>
<parameter key="weighted_mean_precision" value="false"/>
<parameter key="spearman_rho" value="false"/>
<parameter key="kendall_tau" value="false"/>
<parameter key="absolute_error" value="false"/>
<parameter key="relative_error" value="false"/>
<parameter key="relative_error_lenient" value="false"/>
<parameter key="relative_error_strict" value="false"/>
<parameter key="normalized_absolute_error" value="false"/>
<parameter key="root_mean_squared_error" value="true"/>
<parameter key="root_relative_squared_error" value="false"/>
<parameter key="squared_error" value="false"/>
<parameter key="correlation" value="false"/>
<parameter key="squared_correlation" value="false"/>
<parameter key="cross-entropy" value="false"/>
<parameter key="margin" value="false"/>
<parameter key="soft_margin_loss" value="false"/>
<parameter key="logistic_loss" value="false"/>
<parameter key="skip_undefined_labels" value="true"/>
<list key="class_weights"/>
<connect from_port="model" to_op="Apply Model (4)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (4)" to_port="unlabelled data"/>
<connect from_op="Apply Model (4)" from_port="labelled data" to_op="Multiply (3)" to_port="input"/>
<connect from_op="Multiply (3)" from_port="output 1" to_op="Performance (4)" to_port="labelled data"/>
<connect from_op="Multiply (3)" from_port="output 2" to_op="Performance (3)" to_port="labelled data"/>
<connect from_op="Performance (3)" from_port="performance" to_port="performance 2"/>
<connect from_op="Performance (3)" from_port="example set" to_port="test set results"/>
<connect from_op="Performance (4)" from_port="performance" to_port="performance 1"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
<portSpacing port="sink_performance 3" spacing="0"/>
</process>
<operator activated="true" class="write_excel" compatibility="9.1.000" expanded="true" height="82" name="Write Excel (3)" width="90" x="707" y="595">
<parameter key="excel_file" value="E:\AIED_New\AIED_GBT_Test_Predictions_CV\CV_Predictions_GBT_40_Attributes.xlsx"/>
<parameter key="file_format" value="xlsx"/>
<parameter key="sheet_name" value="RapidMiner Data"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="number_format" value="#.0"/>
<operator activated="true" class="select_attributes" compatibility="9.1.000" expanded="true" height="82" name="Select Attributes" width="90" x="380" y="34">
<parameter key="attributes" value="Ln|Ln-1|RES_BORED|RES_CONFUSED|RES_FRUSTRATED|RES_GAMING|RES_OFFTASK|attemptCount|correct|endsWithScaffolding|frIsHelpRequest|frIsHelpRequestScaffolding|frPast5HelpRequest|frPast5WrongCount|frPast8HelpRequest|frPast8WrongCount|frTotalSkillOpportunitiesScaffolding|hint|hintCount|hintTotal|manywrong|original|past8BottomOut|problemType|scaffold|skill|sumRight|sumTimePerSkill|timeGreater10SecAndNextActionRight|timeSinceSkill|timeTaken|totalFrPastWrongCount|totalFrPercentPastWrong|totalFrSkillOpportunities|totalFrSkillOpportunitiesByScaffolding|totalFrTimeOnSkill|totalTimeByPercentCorrectForskill"/>
<operator activated="true" class="concurrency:cross_validation" compatibility="9.1.000" expanded="true" height="187" name="Cross Validation (3)" width="90" x="581" y="34">
<operator activated="true" class="h2o:gradient_boosted_trees" compatibility="9.0.000" expanded="true" height="103" name="Gradient Boosted Trees" width="90" x="112" y="34">
<connect from_port="training set" to_op="Gradient Boosted Trees" to_port="training set"/>
<connect from_op="Gradient Boosted Trees" from_port="model" to_port="model"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.1.000" expanded="true" height="82" name="Apply Model (3)" width="90" x="45" y="34">
<operator activated="true" class="multiply" compatibility="9.1.000" expanded="true" height="124" name="Multiply (4)" width="90" x="45" y="136"/>
<operator activated="true" class="performance" compatibility="9.1.000" expanded="true" height="82" name="Performance" width="90" x="179" y="340">
<operator activated="true" class="performance_classification" compatibility="9.1.000" expanded="true" height="82" name="Performance (5)" width="90" x="246" y="238">
<connect from_port="model" to_op="Apply Model (3)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (3)" to_port="unlabelled data"/>
<connect from_op="Apply Model (3)" from_port="labelled data" to_op="Multiply (4)" to_port="input"/>
<connect from_op="Multiply (4)" from_port="output 2" to_op="Performance (5)" to_port="labelled data"/>
<connect from_op="Multiply (4)" from_port="output 3" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="performance 3"/>
<connect from_op="Performance" from_port="example set" to_port="test set results"/>
<connect from_op="Performance (5)" from_port="performance" to_port="performance 1"/>
<portSpacing port="sink_performance 4" spacing="0"/>
</process>
<operator activated="true" class="write_excel" compatibility="9.1.000" expanded="true" height="82" name="Write Excel" width="90" x="715" y="187">
<parameter key="excel_file" value="E:\AIED_New\AIED_GBT_Test_Predictions_CV\CV_Predictions_GBT_38_Attributes.xlsx"/>
<operator activated="true" class="select_attributes" compatibility="9.1.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="380" y="238">
<parameter key="attributes" value="Ln|Ln-1|RES_BORED|RES_CONFUSED|RES_FRUSTRATED|RES_GAMING|RES_OFFTASK|attemptCount|correct|endsWithScaffolding|frIsHelpRequest|frIsHelpRequestScaffolding|frPast5HelpRequest|frPast5WrongCount|frPast8HelpRequest|frPast8WrongCount|frTotalSkillOpportunitiesScaffolding|hint|hintCount|hintTotal|manywrong|original|past8BottomOut|problemType|scaffold|skill|sumRight|sumTimePerSkill|timeGreater10SecAndNextActionRight|timeSinceSkill|timeTaken|totalFrAttempted|totalFrPastWrongCount|totalFrPercentPastWrong|totalFrSkillOpportunities|totalFrSkillOpportunitiesByScaffolding|totalFrTimeOnSkill|totalTimeByPercentCorrectForskill"/>
<operator activated="true" class="concurrency:cross_validation" compatibility="9.1.000" expanded="true" height="166" name="Cross Validation (2)" width="90" x="581" y="238">
<operator activated="true" class="h2o:gradient_boosted_trees" compatibility="9.0.000" expanded="true" height="103" name="Gradient Boosted Trees (2)" width="90" x="112" y="34">
<connect from_port="training set" to_op="Gradient Boosted Trees (2)" to_port="training set"/>
<connect from_op="Gradient Boosted Trees (2)" from_port="model" to_port="model"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.1.000" expanded="true" height="82" name="Apply Model (2)" width="90" x="45" y="34">
<operator activated="true" class="multiply" compatibility="9.1.000" expanded="true" height="103" name="Multiply (2)" width="90" x="45" y="136"/>
<operator activated="true" class="performance" compatibility="9.1.000" expanded="true" height="82" name="Performance (8)" width="90" x="246" y="340">
<operator activated="true" class="performance_classification" compatibility="9.1.000" expanded="true" height="82" name="Performance (2)" width="90" x="246" y="85">
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Multiply (2)" to_port="input"/>
<connect from_op="Multiply (2)" from_port="output 1" to_op="Performance (2)" to_port="labelled data"/>
<connect from_op="Multiply (2)" from_port="output 2" to_op="Performance (8)" to_port="labelled data"/>
<connect from_op="Performance (8)" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance (8)" from_port="example set" to_port="test set results"/>
<connect from_op="Performance (2)" from_port="performance" to_port="performance 2"/>
</process>
<operator activated="true" class="write_excel" compatibility="9.1.000" expanded="true" height="82" name="Write Excel (2)" width="90" x="707" y="340">
<parameter key="excel_file" value="E:\AIED_New\AIED_GBT_Test_Predictions_CV\CV_Predictions_GBT_39_Attributes.xlsx"/>
<connect from_op="Retrieve Assistment_Data_Labels" from_port="output" to_op="Multiply (6)" to_port="input"/>
<connect from_op="Multiply (6)" from_port="output 1" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Multiply (6)" from_port="output 2" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Multiply (6)" from_port="output 3" to_op="Select Attributes (3)" to_port="example set input"/>
<connect from_op="Select Attributes (3)" from_port="example set output" to_op="Cross Validation (4)" to_port="example set"/>
<connect from_op="Cross Validation (4)" from_port="test result set" to_op="Write Excel (3)" to_port="input"/>
<connect from_op="Cross Validation (4)" from_port="performance 1" to_port="result 5"/>
<connect from_op="Cross Validation (4)" from_port="performance 2" to_port="result 6"/>
<connect from_op="Write Excel (3)" from_port="through" to_port="result 9"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Cross Validation (3)" to_port="example set"/>
<connect from_op="Cross Validation (3)" from_port="test result set" to_op="Write Excel" to_port="input"/>
<connect from_op="Cross Validation (3)" from_port="performance 1" to_port="result 1"/>
<connect from_op="Cross Validation (3)" from_port="performance 2" to_port="result 2"/>
<connect from_op="Cross Validation (3)" from_port="performance 3" to_port="result 10"/>
<connect from_op="Write Excel" from_port="through" to_port="result 7"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Cross Validation (2)" to_port="example set"/>
<connect from_op="Cross Validation (2)" from_port="test result set" to_op="Write Excel (2)" to_port="input"/>
<connect from_op="Cross Validation (2)" from_port="performance 1" to_port="result 3"/>
<connect from_op="Cross Validation (2)" from_port="performance 2" to_port="result 4"/>
<connect from_op="Write Excel (2)" from_port="through" to_port="result 8"/>
<portSpacing port="sink_result 5" spacing="0"/>
<portSpacing port="sink_result 6" spacing="0"/>
<portSpacing port="sink_result 7" spacing="0"/>
<portSpacing port="sink_result 8" spacing="0"/>
<portSpacing port="sink_result 9" spacing="0"/>
<portSpacing port="sink_result 10" spacing="0"/>
<portSpacing port="sink_result 11" spacing="0"/>
</process>
</process>
Thanks,
Varun
