I'm trying to make use of my Loop Attributes with Generate Attributes inside of it. I did it with the help of refencing closely to this video (
https://academy.rapidminer.com/learn/video/loop-attributes),
However, the "Not Enough Iterations" popped out when I run the process.
It states that the
minimum number of iterations must not be smaller than 1 but was '0'.
I don't see anything with regards to 'Iteration' appearing in the above mentioned video as well as in the parameters of Loop Attributes/Generate Attributes.
How do I solve it?
AY
