<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.1.000" expanded="true" height="68" name="Iris" origin="GENERATED_TUTORIAL" width="90" x="45" y="136"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="concurrency:k_means" compatibility="9.1.000" expanded="true" height="82" name="Clustering" width="90" x="179" y="136"> <parameter key="add_cluster_attribute" value="true"/> <parameter key="add_as_label" value="false"/> <parameter key="remove_unlabeled" value="false"/> <parameter key="k" value="3"/> <parameter key="max_runs" value="10"/> <parameter key="determine_good_start_values" value="true"/> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="mixed_measure" value="MixedEuclideanDistance"/> <parameter key="nominal_measure" value="NominalDistance"/> <parameter key="numerical_measure" value="EuclideanDistance"/> <parameter key="divergence" value="SquaredEuclideanDistance"/> <parameter key="kernel_type" value="radial"/> <parameter key="kernel_gamma" value="1.0"/> <parameter key="kernel_sigma1" value="1.0"/> <parameter key="kernel_sigma2" value="0.0"/> <parameter key="kernel_sigma3" value="2.0"/> <parameter key="kernel_degree" value="3.0"/> <parameter key="kernel_shift" value="1.0"/> <parameter key="kernel_a" value="1.0"/> <parameter key="kernel_b" value="0.0"/> <parameter key="max_optimization_steps" value="100"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <description align="center" color="green" colored="true" width="126">Make any type of clustering.<br>This creates a new attribute:<br>&quot;cluster&quot;</description> </operator> <operator activated="true" class="discretize_by_frequency" compatibility="7.1.001" expanded="true" height="103" name="Discretize by Frequency" origin="GENERATED_TUTORIAL" width="90" x="380" y="136"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="use_sqrt_of_examples" value="false"/> <parameter key="number_of_bins" value="5"/> <parameter key="range_name_type" value="short"/> <parameter key="automatic_number_of_digits" value="true"/> <parameter key="number_of_digits" value="-1"/> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="7.1.001" expanded="true" height="103" name="Nominal to Binominal" origin="GENERATED_TUTORIAL" width="90" x="514" y="136"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="transform_binominal" value="true"/> <parameter key="use_underscore_in_name" value="true"/> </operator> <operator activated="true" class="concurrency:loop_values" compatibility="9.1.000" expanded="true" height="82" name="Loop Values" width="90" x="715" y="136"> <parameter key="attribute" value="cluster"/> <parameter key="iteration_macro" value="loop_value"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="filter_examples" compatibility="9.1.000" expanded="true" height="103" name="Filter Examples" width="90" x="112" y="34"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="custom_filters"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"> <parameter key="filters_entry_key" value="cluster.equals.%{loop_value}"/> </list> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="true"/> <description align="center" color="purple" colored="true" width="126">Select only those examples that belong to a certain cluster.<br>See the filter function where during run time the macro %{loop_value}<br/>is repleaced with &quot;cluster_0&quot;, &quot;cluster_1&quot; and &quot;cluster_3&quot;</description> </operator> <operator activated="true" class="concurrency:fp_growth" compatibility="9.1.000" expanded="true" height="82" name="FPGrowth" origin="GENERATED_TUTORIAL" width="90" x="447" y="85"> <parameter key="input_format" value="items in dummy coded columns"/> <parameter key="item_separators" value="|"/> <parameter key="use_quotes" value="false"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character" value="\"/> <parameter key="trim_item_names" value="true"/> <parameter key="min_requirement" value="support"/> <parameter key="min_support" value="0.1"/> <parameter key="min_frequency" value="100"/> <parameter key="min_items_per_itemset" value="1"/> <parameter key="max_items_per_itemset" value="0"/> <parameter key="max_number_of_itemsets" value="1000000"/> <parameter key="find_min_number_of_itemsets" value="false"/> <parameter key="min_number_of_itemsets" value="1"/> <parameter key="max_number_of_retries" value="15"/> <parameter key="requirement_decrease_factor" value="0.9"/> <enumeration key="must_contain_list"/> </operator> <operator activated="true" class="create_association_rules" compatibility="9.1.000" expanded="true" height="82" name="Create Association Rules" origin="GENERATED_TUTORIAL" width="90" x="581" y="85"> <parameter key="criterion" value="confidence"/> <parameter key="min_confidence" value="0.8"/> <parameter key="min_criterion_value" value="0.8"/> <parameter key="gain_theta" value="2.0"/> <parameter key="laplace_k" value="1.0"/> </operator> <connect from_port="input 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="FPGrowth" to_port="example set"/> <connect from_op="FPGrowth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/> <connect from_op="Create Association Rules" from_port="rules" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> <description align="center" color="green" colored="true" height="106" resized="true" width="306" x="433" y="203">Create the association rules</description> </process> <description align="center" color="red" colored="true" width="126">Loop or iterate over the different values for the &quot;cluster&quot; attribute.<br>The iteration macro is then used to filter the examples inside</description> </operator> <connect from_op="Iris" from_port="output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="clustered set" to_op="Discretize by Frequency" to_port="example set input"/> <connect from_op="Discretize by Frequency" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Loop Values" to_port="input 1"/> <connect from_op="Loop Values" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> <description align="center" color="yellow" colored="false" height="96" resized="true" width="230" x="388" y="249">Just create some more attributes,<br/>by splitting the numerical values into ranges</description> </process> </operator> </process>
