I just downloaded FluxMotor and even though I can edit any parameter of the motor, the tests cannot be performed. The error shows the following.
The test Characterization, Datasheet, Motor, Current-Voltage failed due to the following problem:
Cause : Unknown error
Type : Unknown
Ticket Number : #100.18.11 #100.18.10 #100.18.1 #100.18.39
Another person in the forum had the same error, and the answer was that a distance was too narrow, but it does not seem to be the case here.
Attached you can find the zip file generated by the test. I would appreciate it if some could help me out with this, because I cannot improve the design if I cannot simulate it.
Thank you in advance.
