I get blind drawiings without the complete dimensioning, neither texts when importing externally gwenerated files
Thanks
Oriol
You are right: Studio is not reading any dimensions and any text.This is actually not a bug. It just has been implemented this way.
You can measure anything easily with the tools in the Analysis taband even add dimensions with the tools from the Drawing tab if needed.
Antonio
Looking forward having all the data from a dwg/dxf transfered to Studio in next releases (text, literal dimensions, tolerances,...)
Not able to mesure from the entities using Sketch/dimension, neither from drawing/diumensioning
there is no plan to add those functions at the moment.
Here are the links where to learn how to use measuring tools:
https://2022.help.altair.com/2022.1/studio/en_us/topics/studio/analysis/points_distance_t.htm
https://2022.help.altair.com/2022.1/studio/en_us/topics/studio/dimensions/dimension_linear_t_2.htm#task_lm2_3p3_hfb
https://2022.help.altair.com/2022.1/studio/en_us/topics/studio/dimensions/dimension_angular_t_2.htm#task_vbx_kp3_hfb
