<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="operator_toolbox:create_exampleset" compatibility="1.7.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="85"> <parameter key="generator_type" value="comma_separated_text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="input_csv_text" value="Id,Att1 1,A|B|V|A|B 2,C|V|B|C 3,E|R|T|Y|E"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="split" compatibility="9.1.000" expanded="true" height="82" name="Split" width="90" x="179" y="85"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="split_pattern" value="[|]"/> <parameter key="split_mode" value="ordered_split"/> </operator> <operator activated="true" class="transpose" compatibility="9.1.000" expanded="true" height="82" name="Transpose" width="90" x="313" y="85"/> <operator activated="true" class="concurrency:loop_attributes" compatibility="9.1.000" expanded="true" height="82" name="Loop Attributes" width="90" x="447" y="85"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="attribute_name_macro" value="loop_attribute"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="select_attributes" compatibility="9.1.000" expanded="true" height="82" name="Select Attributes" width="90" x="112" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{loop_attribute}"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="remove_duplicates" compatibility="9.1.000" expanded="true" height="103" name="Remove Duplicates" width="90" x="313" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{loop_attribute}"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="treat_missing_values_as_duplicates" value="false"/> </operator> <operator activated="true" class="transpose" compatibility="9.1.000" expanded="true" height="82" name="Transpose (2)" width="90" x="447" y="85"/> <connect from_port="input 1" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Remove Duplicates" to_port="example set input"/> <connect from_op="Remove Duplicates" from_port="example set output" to_op="Transpose (2)" to_port="example set input"/> <connect from_op="Transpose (2)" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="subprocess" compatibility="9.1.000" expanded="true" height="82" name="Union Append" origin="GENERATED_COMMUNITY" width="90" x="581" y="85"> <process expanded="true"> <operator activated="true" class="loop_collection" compatibility="9.1.000" expanded="true" height="82" name="Output (4)" origin="GENERATED_COMMUNITY" width="90" x="45" y="34"> <parameter key="set_iteration_macro" value="true"/> <parameter key="macro_name" value="iteration"/> <parameter key="macro_start_value" value="1"/> <parameter key="unfold" value="false"/> <process expanded="true"> <operator activated="false" breakpoints="after" class="select" compatibility="9.1.000" expanded="true" height="68" name="Select (5)" origin="GENERATED_COMMUNITY" width="90" x="112" y="34"> <parameter key="index" value="%{iteration}"/> <parameter key="unfold" value="false"/> </operator> <operator activated="true" class="branch" compatibility="9.1.000" expanded="true" height="82" name="Branch (2)" origin="GENERATED_COMMUNITY" width="90" x="313" y="34"> <parameter key="condition_type" value="expression"/> <parameter key="expression" value="%{iteration}==1"/> <parameter key="io_object" value="ANOVAMatrix"/> <parameter key="return_inner_output" value="true"/> <process expanded="true"> <connect from_port="condition" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="recall" compatibility="9.1.000" expanded="true" height="68" name="Recall (5)" origin="GENERATED_COMMUNITY" width="90" x="45" y="187"> <parameter key="name" value="LoopData"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="remove_from_store" value="true"/> </operator> <operator activated="true" class="union" compatibility="9.1.000" expanded="true" height="82" name="Union (2)" origin="GENERATED_COMMUNITY" width="90" x="179" y="34"/> <connect from_port="condition" to_op="Union (2)" to_port="example set 1"/> <connect from_op="Recall (5)" from_port="result" to_op="Union (2)" to_port="example set 2"/> <connect from_op="Union (2)" from_port="union" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> </operator> <operator activated="true" class="remember" compatibility="9.1.000" expanded="true" height="68" name="Remember (5)" origin="GENERATED_COMMUNITY" width="90" x="581" y="34"> <parameter key="name" value="LoopData"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="store_which" value="1"/> <parameter key="remove_from_process" value="true"/> </operator> <connect from_port="single" to_op="Branch (2)" to_port="condition"/> <connect from_op="Branch (2)" from_port="input 1" to_op="Remember (5)" to_port="store"/> <connect from_op="Remember (5)" from_port="stored" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="select" compatibility="9.1.000" expanded="true" height="68" name="Select (6)" origin="GENERATED_COMMUNITY" width="90" x="179" y="34"> <parameter key="index" value="%{iteration}"/> <parameter key="unfold" value="false"/> </operator> <connect from_port="in 1" to_op="Output (4)" to_port="collection"/> <connect from_op="Output (4)" from_port="output 1" to_op="Select (6)" to_port="collection"/> <connect from_op="Select (6)" from_port="selected" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="replace_missing_values" compatibility="9.1.000" expanded="true" height="103" name="Replace Missing Values" width="90" x="715" y="85"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default" value="value"/> <list key="columns"/> <parameter key="replenishment_value" value="missing"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="9.1.000" expanded="true" height="82" name="Generate Concatenation" width="90" x="849" y="85"> <parameter key="first_attribute" value="Att1_1"/> <parameter key="second_attribute" value="Att1_2"/> <parameter key="separator" value="|"/> <parameter key="trim_values" value="false"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="9.1.000" expanded="true" height="82" name="Generate Concatenation (2)" width="90" x="983" y="85"> <parameter key="first_attribute" value="Att1_1|Att1_2"/> <parameter key="second_attribute" value="Att1_3"/> <parameter key="separator" value="|"/> <parameter key="trim_values" value="false"/> </operator> <operator activated="true" class="generate_concatenation" compatibility="9.1.000" expanded="true" height="82" name="Generate Concatenation (3)" width="90" x="1117" y="85"> <parameter key="first_attribute" value="Att1_1|Att1_2|Att1_3"/> <parameter key="second_attribute" value="Att1_4"/> <parameter key="separator" value="|"/> <parameter key="trim_values" value="false"/> </operator> <operator activated="true" class="select_attributes" compatibility="9.1.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="1251" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Att1_1|Att1_2|Att1_3|Att1_4"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="sort" compatibility="9.1.000" expanded="true" height="82" name="Sort" width="90" x="1385" y="85"> <parameter key="attribute_name" value="id"/> <parameter key="sorting_direction" value="increasing"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Split" to_port="example set input"/> <connect from_op="Split" from_port="example set output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Loop Attributes" to_port="input 1"/> <connect from_op="Loop Attributes" from_port="output 1" to_op="Union Append" to_port="in 1"/> <connect from_op="Union Append" from_port="out 1" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Generate Concatenation" to_port="example set input"/> <connect from_op="Generate Concatenation" from_port="example set output" to_op="Generate Concatenation (2)" to_port="example set input"/> <connect from_op="Generate Concatenation (2)" from_port="example set output" to_op="Generate Concatenation (3)" to_port="example set input"/> <connect from_op="Generate Concatenation (3)" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
