<div>Dec 23, 2018 2:00:25 PM INFO: No filename given for result file, using stdout for logging results!</div><div><br></div><div>Dec 23, 2018 2:00:25 PM INFO: Process //Keras Samples/boston_housing_prices_regression/boston-housing-prices-regression starts</div><div><br></div><div>Dec 23, 2018 2:00:25 PM WARNING: Example set has no nominal label: using shuffled partition instead of stratified partition</div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: Process failed: operator cannot be executed. Check the log messages...</div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: Here: </div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: Process[1] (Process)</div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: subprocess 'Main Process'</div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: +- Retrieve boston-housing-prices[1] (Retrieve)</div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: +- Set Role[1] (Set Role)</div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: +- Split Data[1] (Split Data)</div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: +- Keras Model[1] (Keras Model)</div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: subprocess 'Executed Process'</div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: | +- Add Core Layer[1] (Add Core Layer)</div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: ==> | +- Add Core Layer (2)[1] (Add Core Layer)</div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: +- Apply Keras Model[0] (Apply Keras Model)</div><div><br></div><div>Dec 23, 2018 2:00:25 PM SEVERE: java.lang.NullPointerException<br><br>
