<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="retrieve" compatibility="9.1.000" expanded="true" height="68" name="Retrieve Golf" width="90" x="179" y="85"><br> <parameter key="repository_entry" value="//Samples/data/Golf"/><br> </operator><br> <operator activated="true" class="select_attributes" compatibility="9.1.000" expanded="true" height="82" name="Select Attributes" width="90" x="313" y="85"><br> <parameter key="attribute_filter_type" value="value_type"/><br> <parameter key="attribute" value=""/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="nominal"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> </operator><br> <operator activated="true" class="set_role" compatibility="9.1.000" expanded="true" height="82" name="Set Role" width="90" x="514" y="85"><br> <parameter key="attribute_name" value="Play"/><br> <parameter key="target_role" value="regular"/><br> <list key="set_additional_roles"/><br> </operator><br> <operator activated="true" class="concurrency:loop_attributes" compatibility="9.1.000" expanded="true" height="82" name="Loop Attributes" width="90" x="715" y="85"><br> <parameter key="attribute_filter_type" value="all"/><br> <parameter key="attribute" value=""/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> <parameter key="attribute_name_macro" value="loop_attribute"/><br> <parameter key="reuse_results" value="false"/><br> <parameter key="enable_parallel_execution" value="true"/><br> <process expanded="true"><br> <operator activated="true" class="set_role" compatibility="9.1.000" expanded="true" height="82" name="Set Role (2)" width="90" x="112" y="34"><br> <parameter key="attribute_name" value="%{loop_attribute}"/><br> <parameter key="target_role" value="label"/><br> <list key="set_additional_roles"/><br> </operator><br> <operator activated="true" class="weight_by_information_gain" compatibility="9.1.000" expanded="true" height="82" name="Weight by Information Gain" width="90" x="380" y="34"><br> <parameter key="normalize_weights" value="false"/><br> <parameter key="sort_weights" value="true"/><br> <parameter key="sort_direction" value="ascending"/><br> </operator><br> <operator activated="false" class="weight_by_gini_index" compatibility="9.1.000" expanded="true" height="82" name="Weight by Gini Index" width="90" x="380" y="136"><br> <parameter key="normalize_weights" value="false"/><br> <parameter key="sort_weights" value="true"/><br> <parameter key="sort_direction" value="ascending"/><br> </operator><br> <operator activated="true" class="weights_to_data" compatibility="9.1.000" expanded="true" height="68" name="Weights to Data" width="90" x="715" y="34"/><br> <operator activated="true" class="generate_attributes" compatibility="9.1.000" expanded="true" height="82" name="Generate Attributes" width="90" x="916" y="34"><br> <list key="function_descriptions"><br> <parameter key="label" value="%{loop_attribute}"/><br> </list><br> <parameter key="keep_all" value="true"/><br> </operator><br> <connect from_port="input 1" to_op="Set Role (2)" to_port="example set input"/><br> <connect from_op="Set Role (2)" from_port="example set output" to_op="Weight by Information Gain" to_port="example set"/><br> <connect from_op="Weight by Information Gain" from_port="weights" to_op="Weights to Data" to_port="attribute weights"/><br> <connect from_op="Weights to Data" from_port="example set" to_op="Generate Attributes" to_port="example set input"/><br> <connect from_op="Generate Attributes" from_port="example set output" to_port="output 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="source_input 2" spacing="0"/><br> <portSpacing port="sink_output 1" spacing="0"/><br> <portSpacing port="sink_output 2" spacing="0"/><br> </process><br> </operator><br> <operator activated="true" class="append" compatibility="9.1.000" expanded="true" height="82" name="Append" width="90" x="916" y="85"><br> <parameter key="datamanagement" value="double_array"/><br> <parameter key="data_management" value="auto"/><br> <parameter key="merge_type" value="all"/><br> </operator><br> <operator activated="true" class="blending:pivot" compatibility="9.1.000" expanded="true" height="82" name="Pivot" width="90" x="1050" y="85"><br> <parameter key="group_by_attributes" value="label"/><br> <parameter key="column_grouping_attribute" value="Attribute"/><br> <list key="aggregation_attributes"><br> <parameter key="Weight" value="average"/><br> </list><br> <parameter key="use_default_aggregation" value="false"/><br> <parameter key="default_aggregation_function" value="first"/><br> </operator><br> <connect from_op="Retrieve Golf" from_port="output" to_op="Select Attributes" to_port="example set input"/><br> <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/><br> <connect from_op="Set Role" from_port="example set output" to_op="Loop Attributes" to_port="input 1"/><br> <connect from_op="Loop Attributes" from_port="output 1" to_op="Append" to_port="example set 1"/><br> <connect from_op="Append" from_port="merged set" to_op="Pivot" to_port="input"/><br> <connect from_op="Pivot" from_port="output" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
