hi kayman, hi sgenzer:
I have the same issue, however I find it hard to execute the hint you have given.
So I my case have two examplesets: Both are keyword-document-matrices, so text data converted to structural data in which each attribute defines a keyword, that appears in the set of documents and each example represents a document.
Now I want to find out which keywords both matrices (Not Examples/Documents) have in common.
I tried both of the described ways, but none was sufficient.
Is there anything that I have to keep in mind doing that?
Hi @sgenzer, sorry.. sure please find the XML code and the data enclosed.
If there is anything wrong with the uploading format, please let me know!
<?xml version="1.0" encoding="UTF-8"?><process version="9.3.000-BETA"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.3.000-BETA" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.3.000-BETA" expanded="true" height="68" name="Retrieve PreppedDatabased_TF_00" width="90" x="45" y="238"> <parameter key="repository_entry" value="//20190923_Outlier Detection/01_Data/012_Single/PreppedDatabased_TF_00"/> </operator> <operator activated="true" class="generate_id" compatibility="9.3.000-BETA" expanded="true" height="82" name="Generate ID (2)" width="90" x="246" y="238"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="47"/> </operator> <operator activated="true" class="retrieve" compatibility="9.3.000-BETA" expanded="true" height="68" name="Retrieve PreppedDatabase" width="90" x="45" y="34"> <parameter key="repository_entry" value="//20190503_PatentDataNLP/001_Data/PreppedDatabase"/> </operator> <operator activated="true" class="generate_id" compatibility="9.3.000-BETA" expanded="true" height="82" name="Generate ID" width="90" x="246" y="34"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="superset" compatibility="9.3.000-BETA" expanded="true" height="82" name="Superset" width="90" x="447" y="34"> <parameter key="include_special_attributes" value="false"/> </operator> <connect from_op="Retrieve PreppedDatabased_TF_00" from_port="output" to_op="Generate ID (2)" to_port="example set input"/> <connect from_op="Generate ID (2)" from_port="example set output" to_op="Superset" to_port="example set 2"/> <connect from_op="Retrieve PreppedDatabase" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Superset" to_port="example set 1"/> <connect from_op="Superset" from_port="superset 1" to_port="result 1"/> <connect from_op="Superset" from_port="superset 2" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.3.000-BETA"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.3.000-BETA" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.3.000-BETA" expanded="true" height="68" name="Retrieve PreppedDatabase (2)" width="90" x="45" y="34"> <parameter key="repository_entry" value="//LocalRepository/PreppedDatabase"/> </operator> <operator activated="true" class="select_attributes" compatibility="9.3.000-BETA" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="transpose" compatibility="9.3.000-BETA" expanded="true" height="82" name="Transpose" width="90" x="313" y="34"/> <operator activated="true" class="select_attributes" compatibility="9.3.000-BETA" expanded="true" height="82" name="Select Attributes (3)" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="retrieve" compatibility="9.3.000-BETA" expanded="true" height="68" name="Retrieve PreppedDatabased_TF_00" width="90" x="45" y="238"> <parameter key="repository_entry" value="//LocalRepository/PreppedDatabased_TF_00"/> </operator> <operator activated="true" class="select_attributes" compatibility="9.3.000-BETA" expanded="true" height="82" name="Select Attributes (2)" width="90" x="179" y="238"> <parameter key="attribute_filter_type" value="value_type"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="transpose" compatibility="9.3.000-BETA" expanded="true" height="82" name="Transpose (2)" width="90" x="313" y="238"/> <operator activated="true" class="select_attributes" compatibility="9.3.000-BETA" expanded="true" height="82" name="Select Attributes (4)" width="90" x="447" y="238"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="concurrency:join" compatibility="9.3.000-BETA" expanded="true" height="82" name="Join" width="90" x="648" y="136"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="inner"/> <parameter key="use_id_attribute_as_key" value="true"/> <list key="key_attributes"/> <parameter key="keep_both_join_attributes" value="false"/> </operator> <connect from_op="Retrieve PreppedDatabase (2)" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Select Attributes (3)" to_port="example set input"/> <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Retrieve PreppedDatabased_TF_00" from_port="output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Transpose (2)" to_port="example set input"/> <connect from_op="Transpose (2)" from_port="example set output" to_op="Select Attributes (4)" to_port="example set input"/> <connect from_op="Select Attributes (4)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
